Nicole04's avatar
Nicole04
11 months ago
Agilex™ 5 EMIF IP for Hard Processor Subsystem (HPS) in Quartus 24.3.1
Good day,
I had a working EMIF IP set up and connected to the HPS in Quartus 24.2. I then upgraded to Quartus 24.3.1 and now can no longer get the EMIF IP to compile without errors. I replaced the old EMIF IP with the HPS EMIF IP (emif_io96b_hps).
I can generate the HDL from Platform Designer without any errors. I get the following error when compiling:
Error(17821): Netlist error at hps_system_emif_io96b_emif_io96b_hps_200_7xwqmpy_emif_0_lpddr4.vhd(275): port 's1_axi4_wuser' of width 64 cannot connect to actual of width 32
Details:
  • Quartus 24.3.1 is used with all IP upgraded.
  • I connect the io96b0_to_hps conduits of the HPS and HPS EMIF together.
  • The channel 1 axi4 wuser is 32 bits wide for both the HPS and EMIF:
  • I am using LPDDR4 with configuration of 2x16 (8Gbit).
  • In hps_system_emif_io96b_emif_io96b_hps_200_7xwqmpy_emif_0_lpddr4.vhd the wuser signals are all of width 32.
I am unable to see where the 64-bit wide signal is and how to fix it.
C:/Firmware/CheetahTacticalRouter/tactical-router-fw/tactical_router_fpga/quartus/ip/hps_system/hps_system_emif_io96b/hps_system_emif_io96b_emif_io96b_hps_200_7xwqmpy/synth/ip/hps_system_emif_io96b_emif_io96b_hps_200_7xwqmpy/hps_system_emif_io96b_emif_io96b_hps_200_7xwqmpy_emif_0_lpddr4/synth/hps_system_emif_io96b_emif_io96b_hps_200_7xwqmpy_emif_0_lpddr4.vhd
  • AdzimZM_Altera's avatar
    AdzimZM_Altera
    Hi Nicole,
    Thank you for your feedback.
    I will try to replicate the issue again with the file that you have shared.
    Adzim
  • mfiorenza's avatar
    mfiorenza
    I have attached my project below for reference if it will help. My project only has the Agilex5 HPS IP, HPS EMIF IP, and FPGA EMIF IP. Both LPDDR4s are the same. HPS EMIF IP compiles successfully but the FPGA EMIF IP leaves me with the error (s0_axi4_wuser) shown above.
  • MM-ATH's avatar
    MM-ATH
    We had similar problems - if we have checked Compile to VHDL (in Platform Designer/generate HDL). if ve have checked Compile to Verilog, problem gone away.
    AdzimZM_Altera
    The issue can be replicated if the EMIF IP is used VHDL code.
    There is a parameter where the axi4_wuser width is determined.
    If it does not use the NoC, the width is set to 64 for axi4_wuser.
    The parameter can be found in the EMIF IP file path *_emif_io96b_lpddr4_0\emif_io96b_lpddr4_200\synth\*_emif_io96b_lpddr4_0_emif_io96b_lpddr4_200_*.sv.
    localparam PORT_AXI_USER_WIDTH = 64,
    localparam PORT_AXI_NOC_USER_WIDTH = 32,
    localparam PORT_AXI_S0_USER_WIDTH = PHY_USE_NOC_INTF ? PORT_AXI_NOC_USER_WIDTH : PORT_AXI_USER_WIDTH,
    Change the PORT_AXI_USER_WIDTH = 64 to 32 can resolve this error message.
    Can you try to change the port width to 32 and check the compilation again?
    Adzim
    • MM-ATH's avatar
      MM-ATH
      Thanks Adzim,
      Yes, this change leads to good compilation on our testing design.
    • Nicole04's avatar
      Nicole04
      Hi Adzim,
      Thank you for looking into this problem. I see multiple files containing this portion. Should it be changed at all cases?
      I changed it at all places and then received the following error:
      Error(13224): Verilog HDL or VHDL error at io0_emif_bank2a_fpga_emif_io96b_lpddr4_200_tq2i7vi_atom_inst_hmc_wide.sv(1041): index 32 is out of range [31:0] for 'ruser'
      Kind regards,
      Nicole
    • Nicole04's avatar
      Nicole04
      Hi Adzim,
      Thank you for the update. Will an IP core update be made?
      My one design works, but another gives a file inclusion error:
      Error(16827): Verilog HDL error at emif_io96b_hps_0_emif_io96b_hps_200_7xwqmpy_emif_0_lpddr4_emif_io96b_cal_200_hpbproa.sv(17): cannot open include file cal_io96b_interface.svh
      Kind regards,
      Nicole
    AdzimZM_Altera
    Hi Nicole,
    I don't think you need to change in all files.
    Make the change in the top IP file should be okay.
    Try to regenerate the IP file again and make the change in the path that I have provided.
    Adzim
  • Nicole04's avatar
    Nicole04
    Hi Adzim,
    The width error seems to be fixed in the Quartus 25.1 version.
    I do however still get the inclusion error. I have tried regenerating the IP, cleaning the project and regenerating again, but the error persists. The included file does exist.
    Error(16827): Verilog HDL error at emif_io96b_hps_0_emif_io96b_hps_300_4hwut5y_emif_0_lpddr4_emif_io96b_lpddr4_300_ljjag6i.sv(17): cannot open include file emif_io96b_interface.svh
    Kind regards,
    Nicole
    • Nicole04's avatar
      Nicole04
      I was able to get a temporary work around, but hopefully this can be fixed in the future.
      I was able to compile the design when the path is made shorter. I had to place my quartus folder directly on the C drive of my PC, because the path for the LPDDR4 EMIF IP is very long.
      Is there a way to shorten the names used in the IP folders?
    AdzimZM_Altera
    Hi Nicole,
    I'm glad that your issue has been resolved.
    We will try to improve the IP file name to avoid this issue in future.
    Currently we cannot set the IP file name shorter automatically.
    Manually edit the IP file name is possible.
    Adzim
