Agilex™ 5 EMIF IP for Hard Processor Subsystem (HPS) in Quartus 24.3.1
The issue can be replicated if the EMIF IP is used VHDL code.
There is a parameter where the axi4_wuser width is determined.
If it does not use the NoC, the width is set to 64 for axi4_wuser.
The parameter can be found in the EMIF IP file path *_emif_io96b_lpddr4_0\emif_io96b_lpddr4_200\synth\*_emif_io96b_lpddr4_0_emif_io96b_lpddr4_200_*.sv.
localparam PORT_AXI_USER_WIDTH = 64,
localparam PORT_AXI_NOC_USER_WIDTH = 32,
localparam PORT_AXI_S0_USER_WIDTH = PHY_USE_NOC_INTF ? PORT_AXI_NOC_USER_WIDTH : PORT_AXI_USER_WIDTH,
Change the PORT_AXI_USER_WIDTH = 64 to 32 can resolve this error message.
Can you try to change the port width to 32 and check the compilation again?
Adzim
Thanks Adzim,
Yes, this change leads to good compilation on our testing design.
