Agilex™ 5 EMIF IP for Hard Processor Subsystem (HPS) in Quartus 24.3.1
The issue can be replicated if the EMIF IP is used VHDL code.
There is a parameter where the axi4_wuser width is determined.
If it does not use the NoC, the width is set to 64 for axi4_wuser.
The parameter can be found in the EMIF IP file path *_emif_io96b_lpddr4_0\emif_io96b_lpddr4_200\synth\*_emif_io96b_lpddr4_0_emif_io96b_lpddr4_200_*.sv.
localparam PORT_AXI_USER_WIDTH = 64,
localparam PORT_AXI_NOC_USER_WIDTH = 32,
localparam PORT_AXI_S0_USER_WIDTH = PHY_USE_NOC_INTF ? PORT_AXI_NOC_USER_WIDTH : PORT_AXI_USER_WIDTH,
Change the PORT_AXI_USER_WIDTH = 64 to 32 can resolve this error message.
Can you try to change the port width to 32 and check the compilation again?
Adzim
- Nicole041 year ago
Hi Adzim,
Thank you for the update. Will an IP core update be made?
My one design works, but another gives a file inclusion error:
Error(16827): Verilog HDL error at emif_io96b_hps_0_emif_io96b_hps_200_7xwqmpy_emif_0_lpddr4_emif_io96b_cal_200_hpbproa.sv(17): cannot open include file cal_io96b_interface.svhKind regards,
Nicole
Hi Adzim,
Thank you for looking into this problem. I see multiple files containing this portion. Should it be changed at all cases?
I changed it at all places and then received the following error:
Error(13224): Verilog HDL or VHDL error at io0_emif_bank2a_fpga_emif_io96b_lpddr4_200_tq2i7vi_atom_inst_hmc_wide.sv(1041): index 32 is out of range [31:0] for 'ruser'Kind regards,
Nicole
- MM-ATH1 year ago
Thanks Adzim,
Yes, this change leads to good compilation on our testing design.
