16 years ago
DDR2-SDRAM on Cyclone III DSP Kit (no NIOS)
I am using the dsp development kit, cyclone iii edition (http://www.altera.com/products/devkits/altera/kit-cyc3-dsp.html).
I wanted to use the DDR2-SDRAM but unfortunately there is no design example for it. So I used the IP-Core called "DDR2 SDRAM High Performance Controller". There I chose Micron MT47H32M16CC-3 x4 + MT47H32M8BP-3 x1, because that is the same like in the Cyclone III Reference Manual. Then I wanted to connect the FPGA pins to the IP-Core, but I wondered where to connect ddr2top_a[15..0], ddr2bot_a[15..0], ddr2top_ba[2..0], ddr2bot_ba[2..0], etc.
Because on the IP-Core there are only buses called mem_addr[12..0] and mem_ba[1..0].
I can change Bank Address Width from 2 Bit to 3 Bit and Row Address Width from 13 Bit to 16 Bit, so it matches, but I still have the problem that I have only one output bus(mem_addr) at the IP-Core for the two buses Top and Bottom.
Has anybody the same board and used the DDR2-SDRAM with the FPGA (and without NIOS) ?
