16 years agoDDR2-SDRAM on Cyclone III DSP Kit (no NIOS)
Hi, I am using the dsp development kit, cyclone iii edition (http://www.altera.com/products/devkits/altera/kit-cyc3-dsp.html). I wanted to use the DDR2-SDRAM but unfortunately there is no ...
16 years ago --- Quote Start --- Those signals are described in this document: http://www.altera.com/literature/ug/ug_ddr_sdram.pdf From the DDR docs, it seems as though those are avalon signals (http://www.altera.com/literature/manual/mnl_avalon_spec.pdf - look for the section on burst transfers). --- Quote End --- I read that but my problem is that local_ready is deasserted after a few write cycles and I do not know why. Reading is no problem but if I write this problem occurs. I have Quartus 9.0. PLL Reference Clock = 100 MHz Memory Clock = 125 MHz Local Interface Clock = 62.5 MHz --- Quote Start --- You can interface to them directly, but why not drop your top level design file into SOPC builder and export the rest of the signals? The SOPC Builder will automagically take care of interfacing to burst enabled slaves even if your master is not. --- Quote End --- How does that work? I am a beginner in Quartus...
