16 years agoDDR2-SDRAM on Cyclone III DSP Kit (no NIOS)
Hi, I am using the dsp development kit, cyclone iii edition (http://www.altera.com/products/devkits/altera/kit-cyc3-dsp.html). I wanted to use the DDR2-SDRAM but unfortunately there is no ...
16 years agoHey immutableman, thanks for your help! :)
--- Quote Start --- Can you post a screen shot of the simulation including all the memory port signals? --- Quote End --- Well, I didn't do any simulation. --- Quote Start --- If you mean ... How do you do it, then ... I am assuming you have an HDL design... --- Quote End --- I have a block design file and there I use some blocks which I created with VHDL. And I just want to read from and write to the DDR2-SDRAM using this Megafunction called "ddr2-sdram high performance controller".
