16 years agoDDR2-SDRAM on Cyclone III DSP Kit (no NIOS)
Hi, I am using the dsp development kit, cyclone iii edition (http://www.altera.com/products/devkits/altera/kit-cyc3-dsp.html). I wanted to use the DDR2-SDRAM but unfortunately there is no ...
16 years ago --- Quote Start --- ...but look at the example projects distributed with the development board... --- Quote End --- There is none... --- Quote Start --- Are you intending to use the top and bottom banks of DDR as one wide interface or two independent ones? --- Quote End --- I don't know. What would be better? Now the problem is that local_ready (output) is low permanently after the first operation (read or write)... dropping the cl (http://alterauserforums.org/forum/showthread.php?t=3995) didn't help.
