PAD ON VIA AND 0201 SIZES OF DECAP ON ARRIA 10 SOC DEVELOPMENT KIT
We have designed several boards with CYCLONE V SOC and even though if the Kit recommended PAD ON VIAs for the FPGA we went ahead standard layout.
Here on ARRIA 10 SOC Kit, we see PAD ON VIA on FPGA with 0201 sizes of DECAP on BOTTOM Layer.
My query is that for ARRIA 10 SOC - whether a PAD ON VIA is needed or whether we can go with a Standard BGA Fanout and 0402 sizes of DECAPS as normal. This helps us in assembly, reduces PCB complexity, reduces costs, aids maintenance. Search for a reliable PCB manufacturer also becomes a task as we have never done this before.
However, we are aware of the fact that in very high speed designs PDN may improve due to PAD ON VIA and 0201 sizes but various people have various opinions in that regard.
Can you please let us know as to whether this is mandatory to have these two features or whether a standard layout can do. We are using SFP+, SGMII and JESD ADCs for our design.
A reply will be very very helpful here.
- AqidAyman_Altera
Thank you for reaching out to Intel FPGA Community.
Could you mind sharing the document you are referring to?
- MHada
Please read me query once again along with this layout file of ARRIA 10 SOC KIT Layout File
- AqidAyman_Altera
From your question, I would suggest you follow the recommended layout instead of the standard layout because we can't be guaranteed on compatibility with the board. For the size of the DECAP, the suggested size is purposely to have less inductance value of the capacitor. If you can obtain less or the same inductance value with 0421 instead of recommended 0201 then it should be okay.
- AqidAyman_Altera
Yes, I understand that you were succeeded with the standard layout on Cyclone V Soc Kit but with the different type of device family that you are using now which in you case is the Arria 10 Soc Kit, I could not guaranteed on the same success rate you get the same for Cyclone device.
I try to find the related document on this issue and you may check the link given below:
Signal Integrity Support Center | Intel
- MHada
Hi Aqid,
Actually I was looking for some specific reasons of the same not working and for that I have floated this question on this group.
As to whether it is the device or my design requirement which will force me to use PAD ON VIAs which I do not want to use for aforementioned reasons.
I still wait for that...
- AqidAyman_Altera
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Thank you.
