PHe's avatar
PHe
7 months ago
Agilex 5E ES Memory Performance Issues
Setup
We observed significant performance issues during sequential memory reads in HPS.
Target device is A5ED065BB32AE6SR0 from the premium dev kit using the GSRD Example.
Sysbench was used to benchmark the memory performance.
Test Results
For comparison, we also performed the test on an STM32 system (Arm Dual Cortex-A7 800 MHz) and the host PC (Ryzen 7 CPU).
 Agilex 5E ESSTM32MP157FHost PC, Ryzen 7
T0 (sequential read)480 MiB/s290 MB/s78972 MiB/s
T1 (sequential write)4058 MiB/s190 MB/s44749 MiB/s
T2 (random read)67 MiB/s373 MB/s3461 MiB/s
T3 (random write)52 MiB/s372 MB/s3608 MiB/s
 The test cases where executed as follows:
T0: sysbench --num-threads=1 --time=10 memory --memory-block-size=4MiB --memory-total-size=64GiB --memory-access-mode="seq" --memory-hugetlb=off --memory-oper=read run
T1: sysbench --num-threads=1 --time=10 memory --memory-block-size=4MiB --memory-total-size=64GiB --memory-access-mode="seq" --memory-hugetlb=off --memory-oper=write run
T2: sysbench --num-threads=1 --time=10 memory --memory-block-size=4MiB --memory-total-size=64GiB --memory-access-mode="rnd" --memory-hugetlb=off --memory-oper=read run
T3: sysbench --num-threads=1 --time=10 memory --memory-block-size=4MiB --memory-total-size=64GiB --memory-access-mode="rnd" --memory-hugetlb=off --memory-oper=write run
Observations
The sequential read operation on the Agilex 5 is significantly (factor 10!) slower than the write operation. Especially when comparing to other systems where the sequential read achieves about a third more throughput.
Sequential Read vs. Write: The sequential read operation on Agilex 5E ES is about 10x slower than the sequential write operation. On other systems, sequential read typically achieves about 30% higher throughput than write.
We found 2 possible issues with the ES devices in the Errata:
  1. Degraded HPS EMIF performance with 2MB L3 Cache: https://docs.altera.com/r/docs/825514/current/agilextm-5-es-device-errata-and-user-guidelines/degraded-hps-emif-performance-with-2mb-l3-cache
  2. HPS EMIF read throughput less than target: https://docs.altera.com/r/docs/825514/current/agilextm-5-es-device-errata-and-user-guidelines/hps-emif-read-throughput-less-than-target
The workaround for 1. is to change the L3-cache to a value different to 2MB. However, this did not improve the performance any way.
For the second errata entry, there is no workaround.
Question
Is the "HPS EMIF read throughput less than target" errata entry the primary cause of the degraded sequential read performance?
If confirmed, is this issue resolved in the series Agilex 5 Devices, and what performance improvements can we expect?
  • Hello PHe,
    You are correct that the performance degradation in the ES devices is due to the errartum you mentioned. This erratum has been addressed in the production devices and the performance is greatly improved.  We have included a benchmark example in the 26.1 Golden System Reference Design (HPS Baseline Example Design) that you can use to run standard benchmarks to see the performance.
    Sue
  • PHe's avatar
    PHe
    Hi Sue,
    That’s great to hear the issue is fixed.
    Unfortunately, I don’t have access to any dev-kits with production Agilex 5 yet due to the long lead times, so I can’t run the benchmarks myself.
    Do you or anyone else have any memory test results comparing the production devices to the ES ones?
    These benchmarks would be really helpful because we are currently evaluating the platform, and “greatly improved” is too vague.
    Best,
    PHe
    • KianHinT_altera's avatar
      KianHinT_altera
      Hi PHe,
      Regarding the memory test result or performance data, I would suggest contacting your local DFAE/FAE guys on this, whether do they have the benchmark data already by running on Agilex5 production example design or DFAE/FAE to submit a request via APS channel. Sorry about this as we do not publish out engineering benchmarking data.
      Kian
