Essen's avatar
Essen
5 months ago
HPS ip configuration in platform designer for uart0 enabling in arria 10 soc
I have software tools Quartus prime pro 26.1, soc eds 20.1 and linaro baremetal tool chain.
Now i configure the HPs ip for uart0 enabling but i am not sure wether it is correct or not, can you please conform it, and guide if there any changes required and if configuration is fine tell me the next steps to do.
Tean D&D,
ESSEN
    • Essen's avatar
      Essen
      Yes, I referred to that documentation. I believe my HPS configuration for enabling UART0 is correct, but I'm not sure what the next steps are on the software side.
      As I mentioned earlier, I have the SoC EDS Command Shell and the Linaro Bare-Metal Toolchain available. Could you share any reference projects, tutorials, application notes, or videos that explain the complete workflow?
      Specifically, I would like to understand:
      1.How to create a simple bare-metal C application that uses UART0 to transmit a "Hello World" message.
      2.How to build/compile the application using the Linaro toolchain.
      3.How to generate the required boot files/images.
      4.How to load and run the application on the target device.
      Any debugging methods to verify UART0 output.
      And the main important thing i wants do all these things in windows (baremetal approach), not using linux.
      so please provide me any video or detailed example which would be helpful.
      Team D&D, ESSEN
  • JitLoonL_Altera's avatar
    JitLoonL_Altera
    Hi Essen​ ,
    If your Platform Designer configuration has UART0 enabled and routed to the dedicated HPS I/O pins, you are on the right track for the hardware side. Ensure you have generated the system and compiled the hardware project to get the .sof file and the handoff files.
    For the software side, developing a bare-metal application on Windows without involving Linux is fully supported using the SoC EDS Embedded Command Shell and the Altera HWLIBs.
    Here is the step-by-step workflow to get your "Hello World" running over UART0:
    1. The Bare-Metal C Application Reference
    You do not need to write this from scratch. You can find the official bare-metal "Hello World" examples in the Altera Open Source GitHub repository here: https://github.com/altera-opensource/intel-socfpga-hwlib/tree/master/examples/A10
    Note: Since you mentioned using the Linaro Bare-Metal Toolchain, make sure you look at the Altera-SoCFPGA-HelloWorld-Baremetal-GNU example, rather than the ARMCC version, so your Makefile aligns with the GCC compiler.
    In the main.c of that example, the core logic relies on #include "alt_uart.h" and #include "alt_clock_manager.h". It handles initializing the clock, initializing the UART0 instance, setting the baud rate (115200), and using alt_printf() or alt_uart_write() to output the string.
    2. Building/Compiling with the Linaro Toolchain
    To build this in Windows:
    Open the SoC EDS Embedded Command Shell (run Embedded_Command_Shell.bat from your SoC EDS installation folder). This environment automatically sets up the paths for the Linaro arm-none-eabi-gcc compiler.
    Navigate to your downloaded Altera-SoCFPGA-HelloWorld-Baremetal-GNU directory.
    Run the make command. This will compile your .c files, link them against the HWLIBs, and generate an .axf (or .elf) executable file.
    3. Generating Boot Files (For SD Card/Flash Boot)
    If you intend to boot this application standalone from hardware (instead of debugging via JTAG):
    Use the bsp-editor to generate the U-Boot SPL (Preloader) from your Quartus hardware handoff folder.
    Compile the Preloader using the Command Shell.
    Use mkimage (available in the EDS shell) to wrap your compiled binary with a U-Boot header, creating an .img or .scr script that U-Boot can execute to jump to your bare-metal entry point.
    4. Loading and Running on the Target Device (JTAG Approach)
    For initial bare-metal development, it is much faster to load and run the code directly into RAM via JTAG using ARM Development Studio (ARM DS), which is bundled with SoC EDS.
    Connect your Intel FPGA Download Cable (USB Blaster) to the Arria 10 board.
    Open ARM DS and create a new Debug Configuration.
    Select the target as Arria 10 SoC and connect via the USB Blaster.
    Point the debugger to your compiled .axf file.
    ARM DS will load the executable directly into the HPS RAM via JTAG and halt at main().
    Try pulling down the GNU example from the GitHub repository and compiling it in the SoC EDS shell. Let us know if you hit any roadblocks during the build phase.
    • Essen's avatar
      Essen
      While installing SoC EDS 20.1, only the SoC EDS Command Shell and Quartus Programmer were installed; the ARM DS software was not installed. Additionally, we do not have an ARM DS license.
      I have already completed the process up to generating the .axf file using the SoC EDS Command Shell and the Linaro bare-metal toolchain. Now, I would like to generate a .bin image file and load it onto the board.
      Is it mandatory to have ARM DS for generating the .bin file and programming the board, or is there an alternative method to accomplish this without ARM DS?
      Team D&D, ESSEN
    JitLoonL_Altera
    Hi Essen,
    Great job getting the .axf generated! To answer your question directly: No, ARM DS and its license are not mandatory for generating the .bin file or for running the application on your board.
    ARM DS is primarily used as an interactive JTAG debugger. If your goal is just to package and run your bare-metal firmware, the free tools already included in the SoC EDS Command Shell are completely sufficient.
    Here is the high-level alternative method to get your code running without ARM DS:
    1. File Conversion: You can convert your .axf file into a raw .bin file using the standard GNU utilities (like objcopy) provided within the SoC EDS Command Shell.
    2. U-Boot Image Creation: Once you have the .bin, you will use the shell's built-in image tools to wrap it with a header so the board's bootloader (U-Boot) can recognize and execute it.
    3. SD Card Execution: Finally, you just copy that newly created image file onto the FAT32 partition of a bootable SD card. When you power on the Arria 10 board, you can interrupt the boot sequence via your UART terminal and instruct U-Boot to load and run your application directly from the SD card.
    Let us know if you would like the specific documentation or guidance on the exact utilities needed for those steps.
  • Essen's avatar
    Essen
    Yes, i need your guidance to do the above things in using soc eds 20.1 and linaro baremetal tool chain.
    And i have one more quesion is these steps are common for cyclone v soc also, or we need to follow different approach to generate .axf file and booting process.
    [ Note: The main thing is we  do all these thing in windows not in linux]
    And could you please confirm the configuration of ip's in platform designer for HPS UART0 provided as image files in first post is ok, or need to modify anything.
    Team D&D, ESSEN
    • KianHinT_altera's avatar
      KianHinT_altera
      Hi Essen,
      Just wondering whether did you manage to resolve this issue?
