Richard_P's avatar
Richard_P
2 years ago
NCONT ERROR in ACK for access 0 : ACK = 0x01 when trying to connect with Arm DS debugger through JTA
I am an embedded developer trying to help bring up a custom Arria 10 board. I can successfully load the SOF file to configure the FPGA using the Intel Quartus Prime Programming utility through a USB Blaster 1 connected to the JTAG interface, but when I try to manually load and run the preloader using the Arm DS debugger I get the "NCONT ERROR in ACK for access 0: ACK = 0x01" message in the Target Console window. From what I have read on the forums, this indicates that there is a JTAG COM issue with the board. I have consulted with our FPGA designer and board layout person, and they tell me the JTAG interface is configured and connected correctly. I tend to believe them since I can successfully load the SOF file through the JTAG interface. After getting the error, the debugger pops up a window stating "The target hardware identity could not be verified. Please check that the target being connected to is of type Arria 10 SoC". I have found a similar post on the Arm DS support website regarding this issue and followed the bare-metal user guide procedure for loading the preloader which worked for that person, but it did not work for me. The preloader instructions can be found at https://www.intel.com/content/www/us/en/docs/programmable/683211/current/import-preloader.html. Any help or suggestions with this issue would be greatly appreciated.
Richard
