Richard_P
3 years agoNCONT ERROR in ACK for access 0 : ACK = 0x01 when trying to connect with Arm DS debugger through JTA
Hi, I am an embedded developer trying to help bring up a custom Arria 10 board. I can successfully load the SOF file to configure the FPGA using the Intel Quartus Prime Programming utility through a...
aikeu
3 years agoHi Richard_P,
Another thing to check is the board is still able to boot up where HPS can run without issue using the GSRD.
Can just download the image file and write to a SD card for the board to boot up and see if there is issue from the UART logs.
https://www.rocketboards.org/foswiki/Documentation/Arria10SoCGSRD#Creating_SD_Card
Aik Eu
