Richard_P
3 years agoNCONT ERROR in ACK for access 0 : ACK = 0x01 when trying to connect with Arm DS debugger through JTA
Hi, I am an embedded developer trying to help bring up a custom Arria 10 board. I can successfully load the SOF file to configure the FPGA using the Intel Quartus Prime Programming utility through a...
aikeu
3 years agoHi Richard_P,
Sorry for late reply. I have tested with the Arria10 Soc Dev kit before. There was no connection error issue when working with it. I think the problem might due to your physical board settings. Example can check if there is any default switches/jumpers settings change from the user guide refering to the link below:
Aik Eu
