How to Generate Altera HAL for HPS?
- 2 months ago
Altera HAL doesn't support HPS currently. Altera HAL is meant generate Nios V BSP.
Can you tell me more what are the uses case you want to have with Altera HAL.
- opexsys2 months ago
Hi Kelvin, thank you for the reply.
Our use case is for high-speed networking. We want to implement the upper layers of the OSI stack in the HPS and the lower levels of the OSI stack in the FPGA fabric. We were interested in the Altera HAL for a few reasons:
1. Portability of the code between different FPGA boards
2. Further decoupling of work between Software Engineers and Hardware Engineers
3. Reducing development time
4. Increasing maintainability of the code
On a side note, is there a reason why the BSP editor is not able to accept SOPCINFO files as the system file for Quartus version 26.1?
Thank you again!
- KelvinK_Altera2 months ago
SOPCINFO files only can apply on Quartus Standard version of BSP editor.
Quartus Pro version BSP editor not able to accept SOPCINFO, only qsys.file can be accept.
