keloke98's avatar
keloke98
5 months ago
Arria 10 SoC Dev Kit Baremetal HPS examples issue & workflow
Hi, I recently acquired an Arria 10 SoC dev kit but I'm really struggling to run either the examples on embedded-software/bare-metal or the ones included in SoC EDS pro 20.1, trying to follow the instructions for both of them, they seem to rely on a old version of SoC EDS which included within ARM DS-5 and the toolchain, but now SoC EDS & ARM DS are separated and I cannot build the examples.
With the new applications the flow for using this examples should remain the same? I mean:
use Pogrammer to program the included .sof inside ghrd (or generate a updated one) ->  open ARM-DS from SoC-EDS with environmental variables assigned and build with new toolchain arm-none-eabi -> run from ARM-DS (can i without license?)
Seems like most of the tools used for running this examples have been discontinued (for example ) so at this point I don't know which workflow should I actually follow.
PD: finally I was able to generate de application.axf from this example Altera-SoCFPGA-HardwareLib-16550-CV-GNU with an old toolchain but I don't know how to program it without a license, for now I don't want to debug anything, just do some simple tests printing by uart
  • KianHinT_altera's avatar
    KianHinT_altera
    Hi Keloke98,
    I will be out of office starting next week, thus response will be slower. Please do try to execute the steps to build the uboot till the creation of the sdcard.img , if everything works , you should see that you are using a new uboot version instead of the old one.
    Kian
  • RaduB_Altera's avatar
    RaduB_Altera
    Looks like the old U-Boot 2021.04 version you are using may behave differently. Please use the one I mentioned above, the U-Boot 2025.07. You can get the SD card from https://releases.rocketboards.org/2025.10/gsrd/a10_gsrd/sdimage.tar.gz, and add your application.axf to the FAT partition.
    If you prefer a small SD card image, that does not have the kernel and rootfs inside, you can build one by using the instructions below. I have used Ubuntu 22.04, but it should work the same also in WSL:
    cd $TOP_FOLDER
    sudo rm -rf sd_card && mkdir sd_card && cd sd_card
    wget https://releases.rocketboards.org/release/2020.11/gsrd/tools/make_sdimage_p3.py
    sed -i 's/\"\-F 32\",//g' make_sdimage_p3.py
    chmod +x make_sdimage_p3.py
    wget https://releases.rocketboards.org/2025.10/gsrd/a10_gsrd/u-boot-splx4.sfp
    mkdir fatfs &&  cd fatfs
    wget https://releases.rocketboards.org/2025.10/gsrd/a10_gsrd/fit_spl_fpga.itb
    wget https://releases.rocketboards.org/2025.10/gsrd/a10_gsrd/u-boot.img
    cp $TOP_FOLDER/intel-socfpga-hwlib/examples/A10/Altera-SoCFPGA-HardwareLib-Timer-A10-GNU/application.axf .
    cd ..
    sudo python3 ./make_sdimage_p3.py -f \
    -P u-boot-splx4.sfp,num=3,format=raw,size=10M,type=A2  \
    -P fatfs/*,num=1,format=vfat,size=20M \
    -s 32M \
    -n sdcard_a10.img
    If you want faster iteration time, and not to have to udpate the SD card each time you change something, you can download the application.axf over network, via TFTP. I use Linux, but there are Windows TFTP servers too, for example https://pjo2.github.io/tftpd64/. See below an example of such usage, note that you will have to replace server ip with your own value:
    => setenv autoload no
    => dhcp
    Speed: 1000, full duplex
    BOOTP broadcast 1
    BOOTP broadcast 2
    BOOTP broadcast 3
    DHCP client bound to address 192.168.1.157 (1011 ms)
    => setenv serverip 192.168.1.101
    => tftp 0x10000000 application.axf
    Using ethernet@ff800000 device
    TFTP from server 192.168.1.101; our IP address is 192.168.1.157
    Filename 'application.axf'.
    Load address: 0x10000000
    Loading: ##################
             5.1 MiB/s
    done
    Bytes transferred = 258864 (3f330 hex)
    => bootelf 0x10000000
    => go 0x00100040
    ## Starting application at 0x00100040 ...
    INFO: Frequency = 300000000.
    INFO: Period    = 1500 millisecond(s).
    INFO: Counter   = 450000000.
    RESULT: Example completed successfully.
    • keloke98's avatar
      keloke98
      Thank you for your reply, the first sd image you sent was too big and won't fit in the sd, but I followed the next steps and build the files "sdcar_a10.img" & "u-boot-splx4.sfp" in a linux VM, but I sitll getting the same error:
      => load mmc 0:1 0x10000000 application.axf
      188384 bytes read in 12 ms (15 MiB/s)
      data abort
      pc : [<3ffc69e2>]          lr : [<3ffc6a13>]
      reloc pc : [<01047a22>]    lr : [<01047a53>]
      sp : 3bf76f60  ip : 00000010     fp : 00000002
      r10: 3ffeb6d8  r9 : 3bf7cee0     r8 : 10000000
      r7 : 00000028  r6 : 00000002     r5 : 10000000  r4 : fc000046
      r3 : 00000018  r2 : 00000000     r1 : 10000040  r0 : 10000040
      Flags: Nzcv  IRQs off  FIQs off  Mode SVC_32 (T)
      Code: 6a2c 442c fb07 4406 (68a3) 079b
      Resetting CPU ...
      resetting ...
      U-Boot SPL 2021.04 (Sep 02 2021 - 08:43:37 +0000)
      DDRCAL: Success
      DDRCAL: Scrubbing ECC RAM (1024 MiB).
        KianHinT_altera
        Hi Keloke98,
        I will set this case to closure and transition this thread to community support since there is no further question.
        Kian
    RaduB_Altera
    I apologize, I was not able to use Ashling RiscFree to succesfully debug either U-Boot or the bare-metal application on the A10 board. I have not used this combination before, so not sure if it is a problem with what I am doing, or something else.
    Note the 25.3 release of Ashling RiscFree installer contains an older version of the tool. You can get the latest available version from the 25.1.1 release at this link: https://www.altera.com/download-center/license-agreement/78291/289e6b3d2979a43f6ddfb46c3eeabfca0b49b3c4?filename=RiscFreeSetup-25.1.1.125-windows.exe.
    Will continue after the holidays, in early January. Hopefully someone else can also help in the meantime.
    I was, however, able to load and run the application from U-Boot, without a debugger. Here is how you can do that, in case it helps:
    1. Compile the HWLIBs design in MSYS2:
    # top folder
    mkdir a10-baremetal
    cd a10-baremetal
    export TOP_FOLDER=$PWD
    # get hwlibs
    cd $TOP_FOLDER
    git clone https://github.com/altera-opensource/intel-socfpga-hwlib
    # install toolchain
    cd $TOP_FOLDER/intel-socfpga-hwlib/tools
    ./install_linaro.sh
    export PATH=$PATH:$PWD/gcc/bin
    export CROSS_COMPILE=arm-eabi-
    # build the example
    cd $TOP_FOLDER/intel-socfpga-hwlib/examples/A10/Altera-SoCFPGA-HardwareLib-Timer-A10-GNU
    # fix newlib location
    sed -i 's|/local||g' Makefile
    # use rm for deleting files
    sed -i s'|cs-rm|rm|' Makefile.inc
    make clean && make SEMIHOSTED=0 MEMORY=ddr
    2. Get the GSRD SD card from https://releases.rocketboards.org/2025.10/gsrd/a10_gsrd/sdimage.tar.gz, extract it and write it to an SD card, for example with https://etcher.balena.io/.
    3. Write the  application.axf to the FAT partition of the SD card. You can use Windows for that. Eject card after that.
    4. Insert SD card, power up board.
    5. Press any key when instructed during countdown, to drop to U-Boot console.
    6. Run the following U-Boot commands to load and execute the bare-metal application:
    bootelf 0x10000000
    go 0x00100040
    For reference, here is all console output:
    U-Boot SPL 2025.07 (Sep 25 2025 - 01:10:31 +0000)
    FPGA: Checking FPGA configuration setting ...
    FPGA: Start to program peripheral/full bitstream ...
    FPGA: Early Release Succeeded.
    DDRCAL: Success
    DDRCAL: SDRAM-ECC initialized success with 334 ms
    FPGA: Skipping configuration ...
    Trying to boot from MMC1
    U-Boot 2025.07 (Sep 25 2025 - 01:10:31 +0000)socfpga_arria10
    CPU:   Altera SoCFPGA Arria 10
    BOOT:  SD/MMC External Transceiver (1.8V)
    Model: Altera SOCFPGA Arria 10
    DRAM:  1 GiB
    Core:  78 devices, 20 uclasses, devicetree: separate
    WDT:   Started watchdog@ffd00300 with servicing every 1000ms (10s timeout)
    MMC:   dwmmc0@ff808000: 0
    Loading Environment from MMC... Reading from MMC(0)... *** Warning - bad CRC, using default environment
    In:    serial
    Out:   serial
    Err:   serial
    Net:
    Warning: ethernet@ff800000 (eth0) using random MAC address - 22:6f:9a:64:64:fe
    eth0: ethernet@ff800000
    Hit any key to stop autoboot:  0
    258864 bytes read in 15 ms (16.5 MiB/s)
    => go 0x00100040
    • keloke98's avatar
      keloke98
      Thank you for your reply Radu, I will wait for your reply after the vacation.
      Followed your steps but still getting an error when launched from uboot and using ddr:
      U-Boot 2021.04 (Sep 02 2021 - 08:43:37 +0000)socfpga_arria10
      DRAM:  1 GiB
      WDT:   Started with servicing (10s timeout)
      Loading Environment from MMC... *** Warning - bad CRC, using default environment
      In:    serial
      Out:   serial
      Err:   serial
      Net:
      Warning: ethernet@ff800000 (eth0) using random MAC address - aa:83:8f:08:35:6f
      188384 bytes read in 11 ms (16.3 MiB/s)
      data abort
      pc : [<3ffc82fc>]          lr : [<3ffc832d>]
      reloc pc : [<0103d33c>]    lr : [<0103d36d>]
      sp : 3bf82f48  ip : 00000010     fp : 00000002
      r10: 00000002  r9 : 3bf88ed0     r8 : 00000000
      Resetting CPU ...
      resetting ...
      But for me the real question is why the assembly looks like this when trying to program using DDR while in theory it has been already initialized by uboot:
      lowlevel_init:
      00100040: andeq r0, r0, r0
      00100044: andeq r0, r0, r0
      00100048: andeq r0, r0, r0
      0010004c: andeq r0, r0, r0
      00100050: andeq r0, r0, r0
      00100054: andeq r0, r0, r0
      00100058: andeq r0, r0, r0
      0010005c: andeq r0, r0, r0
      _socfpga_main:
      00100060: andeq r0, r0, r0
      00100064: andeq r0, r0, r0
      ___mainCRTStartup_from_arm:
      00100068: andeq r0, r0, r0
      0010006c: andeq r0, r0, r0
      _start:
      00100070: movs r0, r0
      00100072: movs r0, r0
      00100074: movs r0, r0
      Do I need a different uboot img to launch baremetal applications without any linux inside?
    RaduB_Altera
    I managed to get a board, and will try it myself. It is an older revision, hopefully it is compatible with the latest versions of tools and software.
    I was able to do this today:
    5. Located latest artifacts:
    6. In MSYS2 ran the following:
    $ pacman -S --needed make gcc git
    $ git clone https://github.com/altera-opensource/intel-socfpga-hwlib
    $ cd intel-socfpga-hwlib/tools
    $ ./install_linaro.sh
    Next I will try to build and run an example as documented at https://www.rocketboards.org/foswiki/Documentation/HWLib#Running_Arria_10_HWLib_Example , but using RiscFree instead of Arm DS.
    Thank you,
    Radu
    • keloke98's avatar
      keloke98
      Hello Radu,
      Were you able to run the example with DDR configuration and Ashling? Because I am stuck in the step 12:
      12. To run debug-spl.ds. In Debugger Tab:
      • Select Run control to be Connect Only
      • Check Run debug initialization debugger script, and click the File System icon to browse for the script /a10_soc_devkit_ghrd/software/bootloader/debug-spl.ds
      Click Debug button
      Not sure where to use this debug-spl.ds because I just get:
      Error in final launch sequence:
      Error downloading the program to target!
        RaduB_Altera
        I realized I cannot do everything on Windows, as compiling U-Boot does not work there. Installed WSL and compiled it there with instructions similar with the ones from https://altera-fpga.github.io/rel-25.3/embedded-designs/arria-10/sx/soc/boot-examples/ug-linux-boot-a10-soc/#boot-from-sd-card:
        # install required pacakges
        sudo apt update
        sudo apt upgrade
        sudo apt install build-essential bison flex libssl-dev bc device-tree-compiler python3 python3-dev swig
        # create top folder
        mkdir a10-baremetal
        cd a10-baremetal
        # get toolchain
        cd $TOP_FOLDER
        wget https://developer.arm.com/-/media/Files/downloads/gnu/14.3.rel1/binrel/arm-gnu-toolchain-14.3.rel1-x86_64-arm-none-linux-gnueabihf.tar.xz
        tar xf arm-gnu-toolchain-14.3.rel1-x86_64-arm-none-linux-gnueabihf.tar.xz
        rm arm-gnu-toolchain-14.3.rel1-x86_64-arm-none-linux-gnueabihf.tar.xz
        export PATH=`pwd`/arm-gnu-toolchain-14.3.rel1-x86_64-arm-none-linux-gnueabihf/bin:$PATH
        export ARCH=arm
        export CROSS_COMPILE=arm-none-linux-gnueabihf-
        # get hardware design files
        cd $TOP_FOLDER
        mkdir a10_soc_devkit_ghrd && cd a10_soc_devkit_ghrd
        wget https://releases.rocketboards.org/2025.10/gsrd/a10_gsrd/ghrd_10as066n2.sof
        wget https://releases.rocketboards.org/2025.10/gsrd/a10_gsrd/hps.xml
        # compile u-boot
        cd $TOP_FOLDER
        rm -rf u-boot-socfpga
        git clone -b QPDS25.3_REL_GSRD_PR https://github.com/altera-fpga/u-boot-socfpga
        cd u-boot-socfpga
        ./arch/arm/mach-socfpga/qts-filter-a10.sh \
        $TOP_FOLDER/a10_soc_devkit_ghrd/hps.xml \
        arch/arm/dts/socfpga_arria10_socdk_sdmmc_handoff.h
        make clean && make mrproper
        make socfpga_arria10_defconfig
        make -j 24
        cd ..
        I prefer Linux, but WSL seems to do a good job too. Using Ubuntu inside WSL, on Windows 11.
        I will continue in the afternoon.
  • keloke98's avatar
    keloke98
    Thank you all for your replies, I was finally able to make the HWLib example work Altera-SoCFPGA-HelloWorld-Baremetal-GNU (only with ocr) by downloading an old toolchain and using Ashlig apparently there was some error when installing linaro in windows and some dependencies were broken but still compiling without errors idk, and you were right about the address but it was a typo in the comment, I was using the other ddr.
    But now I have some error when trying to run the example from the ddr instead of ocr:
    XXX
    COMPILER ?= GNU #COMPILER ?= ARMCC
    MEMORY ?= ddr #MEMORY ?= ocr
    #SEMIHOSTED ?= 1
    SEMIHOSTED ?= 0
    HWLIBS_ROOT := C:/altera_pro/HWLIBS/msys64/home/work/intel-socfpga-hwlib/armv7a/hwlib
    NEWLIB_ROOT := C:/intelFPGA/Toolchains/gcc-arm-8.3-2019.03-i686-mingw32-arm-eabi/arm-eabi
    ADD_CFLAGS_GNU :=
    ADD_CFLAGS_ARMCC :=
    EXAMPLE_SRC := hello.c
    ELF := application.axf
    # These parameters can be overridden
    # LINKER_SCRIPT
    # HWLIBS_SRC
    include Makefile.inc
    XXX
    With ocr it works fine but with ddr it seems to aim to no accessible memory, because this is what I see in disassembly with default linker address:
    XXX
    OUTPUT_FORMAT("elf32-littlearm", "elf32-bigarm", "elf32-littlearm")
    OUTPUT_ARCH(arm)
    ENTRY(_socfpga_main)
    /* Do we need any of these for elf? __DYNAMIC = 0; */
    SECTIONS
      /* Read-only sections, merged into text segment: */
      . = 0x00100040;
      .vector : { *(.vectors*) }
      .interp : { *(.interp) }
      .hash : { *(.hash) }
      .dynsym : { *(.dynsym) }
      .dynstr : { *(.dynstr) }
      .gnu.version : { *(.gnu.version) }
      .gnu.version_d : { *(.gnu.version_d) }
      .gnu.version_r : { *(.gnu.version_r) }
    XXX
    It seems the memory is not accessible and obviously fails and launches uboot again:
    XXX
    lowlevel_init:
    _socfpga_main:
    _start:
    XXX
    But from the uboot command:
    XXX
    => bdinfo
    boot_params = 0x00000100
    DRAM bank   = 0x00000000
    -> start    = 0x00000000
    -> size     = 0x40000000
    flashstart  = 0x00000000
    flashsize   = 0x00000000
    flashoffset = 0x00000000
    baudrate    = 115200 bps
    relocaddr   = 0x3ff8b000
    reloc off   = 0x3ef8afc0
    Build       = 32-bit
    current eth = ethernet@ff800000
    ethaddr     = (not set)
    IP addr     = <NULL>
    fdt_blob    = 0x3bf830d0
    new_fdt     = 0x3bf830d0
    fdt_size    = 0x00005e00
    lmb_dump_all:
        memory.cnt             = 0x1
        memory.size            = 0x0
        memory.reg[0x0].base   = 0x0
                       .size   = 0x40000000
        reserved.cnt           = 0x1
        reserved.size          = 0x0
        reserved.reg[0x0].base = 0x3bf81ecc
                         .size = 0x407e134
    arch_number = 0x00000000
    TLB addr    = 0x3fff0000
    irq_sp      = 0x3bf830c0
    sp start    = 0x3bf830b0
    ARM frequency = 1200 MHz
    DSP frequency = 0 MHz
    DDR frequency = 0 MHz
    Early malloc usage: 1544 / 2000
    XXX
    and shows SDRAM succed msg:
    XXX
    DDRCAL: Success
    DDRCAL: SDRAM-ECC initialized success with 148 ms
    XXX
    By this I understand that SDRAM was properly initialized and from the original 0x00040000 - 0xC0000000 available addresses, I can put my program in around 0x00040000 - 0x3bf00000 but as you see above it doesnt work and don't write the program properly.
    Also i don't understand that if I modify the address to an outside of that range value like 0x50000000 it seems to write the correct data:
    XXX
    lowlevel_init:
    50000000: mrc 15, 0, r0, cr1, cr1, {2}
    50000004: orr r0, r0, #3145728 @ 0x300000
    50000008: mcr 15, 0, r0, cr1, cr1, {2}
    5000000c: mov r0, #15728640 @ 0xf00000
    50000010: mcr 15, 0, r0, cr1, cr0, {2}
    50000014: mov r3, #1073741824 @ 0x40000000
    50000018: vmsr fpexc, r3
    5000001c: bx lr
    _socfpga_main:
    50000020: bl 0x50000000 <lowlevel_init>
    50000024: b 0x50000028 <___mainCRTStartup_from_arm>
    50000028: ldr pc, [pc, #-4] @ 0x5000002c <___mainCRTStartup_from_arm+4>
    5000002c: andpl r0, r0, r1, lsr r0
    _start:
    50000030: ldr r3, [pc, #76] @ (0x50000080 <_start+80>)
    50000032: cmp r3, #0
    50000034: it eq
    50000036: ldreq r3, [pc, #68] @ (0x5000007c <_start+76>)
    50000038: mov sp, r3
    5000003a: sub.w r10, r3, #65536 @ 0x10000
    XXX
    But at the end the program crashes and launches back uboot:
    XXX
    ///// here I launch the program with Ashling
    => data abort
    pc : [<5000363a>] lr : [<5000006d>]
    reloc pc : [<1107d67a>] lr : [<1107a0ad>]
    sp : 0007fff0 ip : ffffffff fp : 00000000
    r10: 00070000 r9 : 3bf83eb0 r8 : 3bf7ded0 r7 : 00000000
    r6: 00000000 r5: 00000000 r4: 50003784
    r3: 00000000 r2: 00000000 r1: 50003511 r0: 00000000
    Flags: nZCv IRQs off FIQs off Mode SVC_32 (T)
    Code: f243 7484 f2c5 0400 (6825) f8d5
    Resetting CPU ...
    resetting ...
    XXX
    I am using the precompiled bootloader files following your reference in GSRD but I guess these are prepared for running only with the linux img and the SDRAM still not completely configured for baremetal? idk
    Any clue?
  • keloke98's avatar
    keloke98
    Thank you all for your quick answers, I was finally able to make it work with the  Ashlig RiscFree tool (only with ocr), the issue was on the installation of some of the linaro dependencies, since I'm working on Windows there were some errors during installation, but by manually installing the old toolchain in gcc-arm-8.3-2019.03-i686-mingw32-arm-eabi i was able to make it work.
    Your are right about the wrong adress but I sent you with a typo, actually i was trying with ddr.
    But now I'm facing another issue while running the Altera-SoCFPGA-HelloWorld-Baremetal-GNU example from HWLIBS, it works fine with ocr:
    COMPILER ?= GNU
    #COMPILER ?= ARMCC
    #MEMORY ?= ddr
    MEMORY ?= ocr
    #SEMIHOSTED ?= 1
    SEMIHOSTED ?= 0
    ADD_CFLAGS_GNU :=
    ADD_CFLAGS_ARMCC :=
    # These parameters can be overriden
    # LINKER_SCRIPT
    # HWLIBS_SRC
    But not when ddr is selected, while debugging with Ashling I see a lot of empty instructions like if the DDR was not accesible:
             lowlevel_init:
    10000000:   andeq   r0, r0, r0
    10000004:   andeq   r0, r0, r0
    10000008:   andeq   r0, r0, r0
    1000000c:   andeq   r0, r0, r0
    10000010:   andeq   r0, r0, r0
    10000014:   andeq   r0, r0, r0
    10000018:   andeq   r0, r0, r0
    1000001c:   andeq   r0, r0, r0
              _socfpga_main:
    10000020:   andeq   r0, r0, r0
    10000024:   andeq   r0, r0, r0
    10000028:   andeq   r0, r0, r0
    1000002c:   andeq   r0, r0, r0
              _start:
    10000030:   ldr     r3, [pc, #76]   @ (0x10000080 <_start+80>)
    10000032:   cmp     r3, #0
    10000034:   it      eq
    10000036:   ldreq   r3, [pc, #68]   @ (0x1000007c <_start+76>)
    10000038:   mov     sp, r3
    1000003a:   sub.w   r10, r3, #65536 @ 0x10000
    1000003e:   movs    r1, #0
    Here I modified the start adress of the linker script to test others than the default but the same happened in  0x00100040
    	      "elf32-littlearm")
    OUTPUT_ARCH(arm)
       __DYNAMIC = 0;    */
    SECTIONS
      . = 0x00100040;
    If I run the command bdinfo in uboot this is what I get:
    => bdinfo
    Build       = 32-bit
    ethaddr     = (not set)
    IP addr     = <NULL>
    lmb_dump_all:
        memory.cnt             = 0x1
        memory.size            = 0x0
                       .size   = 0x40000000
        reserved.cnt           = 0x1
        reserved.size          = 0x0
                         .size = 0x407e134
    irq_sp      = 0x3bf830c0
    DDRCAL: Success
    By this what I understand is that DDR was correctly initialized and from the original 0x0004_0000 - 0xC000_0000 SDRAM address,  0x0004_0000 - 0x3bf8_1ecc are available to run my code, but then in disassembly I see those empty instructions.
    I'm using the precompiled uboot img in Arria10SoCGSRD following your reference, but this is prepared to configure the board to run a linux img not pure baremetal I guess.
    Also that I don't understand is that when I use a direction outside that range in the linker script like 0x50000000 the Disassembly code makes sense and seems accesible:
              lowlevel_init:
    5000001c:   bx      lr
              _socfpga_main:
              _start:
    50000034:   it      eq
    But at the end I still getting an error which crashes the application and launch back uboot:
    Hit any key to stop autoboot:  0 ////////////////(Here I stop manually and launch my code in Ashling ocr works ddr doesnt)
    => data abort
    sp : 0007fff0  ip : 00000000     fp : 00000000
    r10: 00070000  r9 : 3bf83eb0     r8 : 0000000a
    r7 : 00000000  r6 : 00000001     r5 : 00000000  r4 : 50003784
    r3 : 00000000  r2 : 00000000     r1 : 50003511  r0 : 00000000
    Resetting CPU ...
    resetting ...
    Any hint?
    RaduB_Altera
    The latest available instructions are at https://www.rocketboards.org/foswiki/Documentation/HWLib. That does not use SoC EDS. But it still uses the Arm DS for running the resulted binary.
    We also have the Ashlig RiscFree debugger, see https://www.altera.com/products/development-tools/ashling. You can debug A10 bare-metal applications with it. First you could try running up to U-Boot console manually, then download and execute the application with RiscFree. The advantage of RiscFree is that it does not require purchasing a license.
  • Hi,
    Thanks for your feedback. You may need to conver .axf to a Raw Binary .bin file before program it.
    you can use fromelf or arm-none-eabi-objcopy to convert it.
    1. arm-none-eabi-objcopy -O binary application.axf application.bin
    2. copy your application.bin to the board.
    3. execute the program.
    Hope it helps.
    • keloke98's avatar
      keloke98
      Thank you for your reply, I followed your steps but not sure if it was the right way because it is still not working.
      1. Generated the .bin and copied inside sd card
      2. Stopped uboot and launched the application in uboot by:
      => fatload mmc 0:1 0x00100040 application_example_v1_1.bin
      67752 bytes read in 6 ms (10.8 MiB/s)
      => go 0x00100040
      As you can see uboot restarts again without printing anything, this i the makefile configuration in the Altera-SoCFPGA-HardwareLib-16550-CV-GNU example (modified the lines to aim to arria10 instead of cyclone V) :
      COMPILER ?= GNU
      #COMPILER ?= ARMCC
      #MEMORY ?= ddr
      MEMORY ?= ocr
      #SEMIHOSTED ?= 1
      SEMIHOSTED ?= 0
      ADD_CFLAGS_GNU :=
      ADD_CFLAGS_ARMCC :=
      EXAMPLE_SRC := main.c alt_16550_buffer.c alt_16550_prompt.c echo_prompt.c launcher_prompt.c memory_prompt.c
      # LINKER_SCRIPT
      # HWLIBS_SRC
      # SAFECLIB_SRC
      Isn't there another easier way to do this without license?
        KianHinT_altera
        I think the reason why it didn't work is because
        #MEMORY ?= ddr
        MEMORY ?= ocr
        For Arria 10 OCR address starts from 0xFFE00000, https://www.intel.com/content/www/us/en/programmable/hps/arria-10/hps.html#topic/sfo1429891236418.html
        either try changing back to DDR or use the 0xFFE00000 address (if your application bin is smaller than 256KB) as OCRAM is quite small.
        As the design is based on cyclone V, memory address might be different as well, eg Arria 10 Devkit uses UART1 so you might need to change the address to 0xFFC02100
        Could you try Radu suggestion as well, and also just wanted to understand, is there any reason you wanted to use baremetal to show uart printout or whether to just boot into linux and running the hello world example?
