Arria 10 SoC Dev Kit Baremetal HPS examples issue & workflow
MEMORY ?= ddr #MEMORY ?= ocr
#SEMIHOSTED ?= 1
SEMIHOSTED ?= 0
HWLIBS_ROOT := C:/altera_pro/HWLIBS/msys64/home/work/intel-socfpga-hwlib/armv7a/hwlib
NEWLIB_ROOT := C:/intelFPGA/Toolchains/gcc-arm-8.3-2019.03-i686-mingw32-arm-eabi/arm-eabi
ADD_CFLAGS_GNU :=
ADD_CFLAGS_ARMCC :=
EXAMPLE_SRC := hello.c
ELF := application.axf
# These parameters can be overridden
# LINKER_SCRIPT
# HWLIBS_SRC
include Makefile.inc
OUTPUT_ARCH(arm)
ENTRY(_socfpga_main)
/* Do we need any of these for elf? __DYNAMIC = 0; */
SECTIONS
/* Read-only sections, merged into text segment: */
. = 0x00100040;
.vector : { *(.vectors*) }
.interp : { *(.interp) }
.hash : { *(.hash) }
.dynsym : { *(.dynsym) }
.dynstr : { *(.dynstr) }
.gnu.version : { *(.gnu.version) }
.gnu.version_d : { *(.gnu.version_d) }
.gnu.version_r : { *(.gnu.version_r) }
00100040: andeq r0, r0, r0
00100044: andeq r0, r0, r0
00100048: andeq r0, r0, r0
0010004c: andeq r0, r0, r0
00100050: andeq r0, r0, r0
00100054: andeq r0, r0, r0
00100058: andeq r0, r0, r0
0010005c: andeq r0, r0, r0
_socfpga_main:
00100060: andeq r0, r0, r0
00100064: andeq r0, r0, r0
___mainCRTStartup_from_arm:
00100068: andeq r0, r0, r0
0010006c: andeq r0, r0, r0
_start:
00100070: movs r0, r0
00100072: movs r0, r0
00100074: movs r0, r0
boot_params = 0x00000100
DRAM bank = 0x00000000
-> start = 0x00000000
-> size = 0x40000000
flashstart = 0x00000000
flashsize = 0x00000000
flashoffset = 0x00000000
baudrate = 115200 bps
relocaddr = 0x3ff8b000
reloc off = 0x3ef8afc0
Build = 32-bit
current eth = ethernet@ff800000
ethaddr = (not set)
IP addr = <NULL>
fdt_blob = 0x3bf830d0
new_fdt = 0x3bf830d0
fdt_size = 0x00005e00
lmb_dump_all:
memory.cnt = 0x1
memory.size = 0x0
memory.reg[0x0].base = 0x0
.size = 0x40000000
reserved.cnt = 0x1
reserved.size = 0x0
reserved.reg[0x0].base = 0x3bf81ecc
.size = 0x407e134
arch_number = 0x00000000
TLB addr = 0x3fff0000
irq_sp = 0x3bf830c0
sp start = 0x3bf830b0
ARM frequency = 1200 MHz
DSP frequency = 0 MHz
DDR frequency = 0 MHz
Early malloc usage: 1544 / 2000
and shows SDRAM succed msg:
XXX
U-Boot SPL 2021.04 (Sep 02 2021 - 08:43:37 +0000)
FPGA: Checking FPGA configuration setting ...
FPGA: Start to program peripheral/full bitstream ...
FPGA: Early Release Succeeded.
DDRCAL: Success
DDRCAL: Scrubbing ECC RAM (1024 MiB).
DDRCAL: SDRAM-ECC initialized success with 148 ms
FPGA: Skipping configuration ...
WDT: Started with servicing (10s timeout)
Trying to boot from MMC1
XXX
By this I understand that SDRAM was properly initialized and from the original 0x00040000 - 0xC0000000 available addresses, I can put my program in around 0x00040000 - 0x3bf00000 but as you see above it doesnt work and don't write the program properly.
Also i don't understand that if I modify the address to an outside of that range value like 0x50000000 it seems to write the correct data:
XXX
lowlevel_init:
50000000: mrc 15, 0, r0, cr1, cr1, {2}
50000004: orr r0, r0, #3145728 @ 0x300000
50000008: mcr 15, 0, r0, cr1, cr1, {2}
5000000c: mov r0, #15728640 @ 0xf00000
50000010: mcr 15, 0, r0, cr1, cr0, {2}
50000014: mov r3, #1073741824 @ 0x40000000
50000018: vmsr fpexc, r3
5000001c: bx lr
_socfpga_main:
50000020: bl 0x50000000 <lowlevel_init>
50000024: b 0x50000028 <___mainCRTStartup_from_arm>
50000028: ldr pc, [pc, #-4] @ 0x5000002c <___mainCRTStartup_from_arm+4>
5000002c: andpl r0, r0, r1, lsr r0
_start:
50000030: ldr r3, [pc, #76] @ (0x50000080 <_start+80>)
50000032: cmp r3, #0
50000034: it eq
50000036: ldreq r3, [pc, #68] @ (0x5000007c <_start+76>)
50000038: mov sp, r3
5000003a: sub.w r10, r3, #65536 @ 0x10000
XXX
But at the end the program crashes and launches back uboot:
XXX
Hit any key to stop autoboot: 0
///// here I launch the program with Ashling
=> data abort
pc : [<5000363a>] lr : [<5000006d>]
reloc pc : [<1107d67a>] lr : [<1107a0ad>]
sp : 0007fff0 ip : ffffffff fp : 00000000
r10: 00070000 r9 : 3bf83eb0 r8 : 3bf7ded0 r7 : 00000000
r6: 00000000 r5: 00000000 r4: 50003784
r3: 00000000 r2: 00000000 r1: 50003511 r0: 00000000
Flags: nZCv IRQs off FIQs off Mode SVC_32 (T)
Code: f243 7484 f2c5 0400 (6825) f8d5
Resetting CPU ...
resetting ...
XXX
I am using the precompiled bootloader files following your reference in GSRD but I guess these are prepared for running only with the linux img and the SDRAM still not completely configured for baremetal? idk
Any clue?
