I'm sorry I didn't understand either of your questions. The RGMII ports from the TSE need to be connected to the relevant FPGA pins. I don't know what you mean by "data[4]" "data[32]" and "connect with"
i got it, it use RGMII to connect the output pin of top layer back to your previous question, i got no response after press auto analysis in signalTap, and capture a diagram for your reference. i do not know how to use signaltap, i guess to press programmer transfer the VHDL to chip first and then press cancel the IP Plus messagebox and then press auto analysis in signaltap - Altera_Forum
use the first option instead of auto analysis, and this will only run one time. Did you set any trigger?
You musn't cancel the IP plus messagebox, because all your unlicensed cores will stop working. To be able to use evaluation and signaltap at the same time, you need to run one of the two tools (signaltap or the quatrus programmer) separately instead of from the Quartus menu. You will find them in C:\altera\xx.x\quartus\bin (programmer is quartus_pgmw.exe, signaltap is quartus_stpw.exe). Then you can program your FPGA, keep the IP Plus window open, and use signaltap at the same time. - Altera_Forum
https://skydrive.live.com/redir?resid=e0ed7271c68be47c!350
https://skydrive.live.com/redir?resid=e0ed7271c68be47c!349 i find it that quite easy to get not compatible error or only can run once after press run then stop the result is in above picture, i have edited code, is it connection correct? i am using CLOCK_50, why ENET0_TX_CLK do not have 101010 and only 1 and i begin to confused whether using input or output for some pins where is wrong?LIBRARY ieee; USE ieee.std_logic_1164.all; entity Transmit2 is port ( CLOCK_50 : IN STD_LOGIC; SW : IN STD_LOGIC_VECTOR(17 DOWNTO 0); ENET0_TX_CLK : OUT STD_LOGIC; ENET0_TX_DATA : OUT STD_LOGIC_VECTOR(3 DOWNTO 0); ENET0_TX_EN : OUT STD_LOGIC; ENET0_RX_CLK : IN STD_LOGIC; ENET0_RX_DATA : IN STD_LOGIC_VECTOR(3 DOWNTO 0); ENET0_RX_DV : IN STD_LOGIC ); end entity Transmit2; architecture syn of Transmit2 is component tether2 is port ( ff_tx_data : IN STD_LOGIC_VECTOR (31 DOWNTO 0); ff_tx_clk : IN STD_LOGIC; ff_tx_eop : IN STD_LOGIC; ff_tx_sop : IN STD_LOGIC; ff_tx_wren : IN STD_LOGIC; read : IN STD_LOGIC; writedata : IN STD_LOGIC_VECTOR (31 DOWNTO 0); write : IN STD_LOGIC; clk : IN STD_LOGIC; reset : IN STD_LOGIC; --tx_clk : IN STD_LOGIC; set_10 : IN STD_LOGIC; set_1000 : IN STD_LOGIC; ff_tx_crc_fwd : IN STD_LOGIC; ff_tx_rdy : OUT STD_LOGIC; readdata : OUT STD_LOGIC_VECTOR (31 DOWNTO 0); ena_10 : OUT STD_LOGIC; eth_mode : OUT STD_LOGIC; ff_tx_a_full : OUT STD_LOGIC; ff_tx_a_empty : OUT STD_LOGIC; magic_wakeup : OUT STD_LOGIC; tx_clk : IN STD_LOGIC; m_tx_d2 : OUT STD_LOGIC_VECTOR (3 DOWNTO 0); m_tx_en2 : IN STD_LOGIC; rx_clk : IN STD_LOGIC; m_rx_d2 : IN STD_LOGIC_VECTOR (3 DOWNTO 0); m_rx_en2 : IN STD_LOGIC ); end component tether2; -- signal clk_10 : std_logic; signal clk_sys : std_logic; signal pll_locked : std_logic; signal spi_cs_n : std_logic; constant whilelooptrue :STD_LOGIC := '1'; constant enableit : STD_LOGIC := '1'; constant disableit : STD_LOGIC := '0'; signal set_10_external : STD_LOGIC; signal set_100_external : STD_LOGIC; constant mac: std_logic_vector(47 downto 0) := X"CB90ADD27810"; constant preamble : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"55"; -- 8 bits * 2 = 16, 4 bits one hex constant SFD : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"D5"; -- 8 bits * 2 = 16 constant dest_mac_addr1 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"10"; constant dest_mac_addr2 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"78"; constant dest_mac_addr3 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"D2"; constant dest_mac_addr4 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"AD"; constant dest_mac_addr5 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"90"; constant dest_mac_addr6 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"CB"; constant src_mac_addr1 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"00"; constant src_mac_addr2 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"12"; constant src_mac_addr3 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"34"; constant src_mac_addr4 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"56"; constant src_mac_addr5 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"78"; constant src_mac_addr6 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"90"; constant payload : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"4B"; constant wholepacketlength1 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"00"; constant wholepacketlength2 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"20"; constant emptyhex : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"00"; constant emptytwobits : STD_LOGIC_VECTOR (1 DOWNTO 0) := "00"; signal tx_data : STD_LOGIC_VECTOR(31 DOWNTO 0); signal macaddr_data : STD_LOGIC_VECTOR(31 DOWNTO 0); signal CheckSumResult : STD_LOGIC_VECTOR (31 DOWNTO 0); signal CheckSumValid : STD_LOGIC; signal startpacket : STD_LOGIC; signal endpacket : STD_LOGIC; signal ff_tx_wren_enable : STD_LOGIC; signal ff_tx_rdy : STD_LOGIC; signal ena_10 : STD_LOGIC; signal eth_mode : STD_LOGIC; signal ff_tx_a_full : STD_LOGIC; signal ff_tx_a_empty : STD_LOGIC; signal magic_wakeup : STD_LOGIC; signal beginwrite : STD_LOGIC; begin H1:tether2 port map ( -- Important connection between output pin and TSE tx_clk => CLOCK_50,--: IN STD_LOGIC; m_tx_d2 => ENET0_TX_DATA,--: OUT STD_LOGIC_VECTOR(3 DOWNTO 0); --m_tx_en2 => ENET0_TX_EN,--: OUT STD_LOGIC m_tx_en2 => '1',--: OUT STD_LOGIC rx_clk => ENET0_RX_CLK, --: OUT STD_LOGIC; m_rx_d2 => ENET0_RX_DATA, --: IN STD_LOGIC_VECTOR(3 DOWNTO 0); m_rx_en2 => ENET0_RX_DV, --: IN STD_LOGIC; -- Important connection between output pin and TSE ff_tx_data => tx_data, ff_tx_clk => CLOCK_50, ff_tx_eop => endpacket, ff_tx_sop => startpacket, ff_tx_wren => ff_tx_wren_enable, read => disableit, writedata => macaddr_data, write => beginwrite, clk => CLOCK_50, reset => disableit, --tx_clk => CLOCK_50, set_10 => set_10_external, set_1000 => set_100_external, ff_tx_crc_fwd => enableit, ff_tx_rdy => ff_tx_rdy, ena_10 => ena_10, eth_mode => eth_mode, --0 = 10/100Mbps, 1 = 1000Mbps : OUT STD_LOGIC; ff_tx_a_full => ff_tx_a_full, ff_tx_a_empty => ff_tx_a_empty, magic_wakeup => magic_wakeup ); process(CLOCK_50) VARIABLE last_clk : std_logic := '0'; VARIABLE counter : integer := 0; VARIABLE last_counter : integer := 0; begin ENET0_TX_CLK <= CLOCK_50; if rising_edge(CLOCK_50) then --if SW(0) = '1' then if (counter = 0) then ENET0_TX_EN <= '1'; beginwrite <= '1'; ff_tx_wren_enable <= enableit; macaddr_data <=mac(31 downto 0); startpacket <= enableit; tx_data <= dest_mac_addr1 & dest_mac_addr2 & dest_mac_addr3 & dest_mac_addr4; end if; if (counter = 1) then macaddr_data(15 downto 0) <=mac(47 downto 32); beginwrite <= '0'; startpacket <= disableit; tx_data <= dest_mac_addr5 & dest_mac_addr6 & src_mac_addr1 & src_mac_addr2; end if; if (counter = 2) then tx_data <= src_mac_addr3 & src_mac_addr4 & src_mac_addr5 & src_mac_addr6; end if; if (counter = 3) then tx_data <= wholepacketlength1 & wholepacketlength2 & payload & emptyhex; endpacket <= enableit; end if; if (counter >= 4) then endpacket <= disableit; ff_tx_wren_enable <= disableit; beginwrite <= '0'; counter := 0; end if; last_counter := counter; counter := counter + 1; --else --beginwrite <= '0'; --end if; last_clk := CLOCK_50; end if; end process; end architecture syn; - Altera_Forum
I don't really understand where the '2' in m_rx_d2 and m_rx_en2 is coming from, and why m_tx_en2 is an input.
Except for that, it seems that none of the problems I've listed in post# 8 have been addressed. - Altera_Forum
ENET0_TX_DATA do not have data to output to my computer, ENET0_TX_CLK do not have signal like clocking 1 0 1 0 ... , why only 1
i prevent mix up with original m_tx_d, so i rename it to indicate which are output pin i guess to input tx_data to ff_tx_data then m_tx_d2 will output to enet0_tx_data, is it correct?LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY tether2 IS PORT ( ff_tx_data : IN STD_LOGIC_VECTOR (31 DOWNTO 0); ff_tx_clk : IN STD_LOGIC; ff_tx_eop : IN STD_LOGIC; ff_tx_sop : IN STD_LOGIC; ff_tx_wren : IN STD_LOGIC; read : IN STD_LOGIC; writedata : IN STD_LOGIC_VECTOR (31 DOWNTO 0); write : IN STD_LOGIC; clk : IN STD_LOGIC; reset : IN STD_LOGIC; set_10 : IN STD_LOGIC; set_1000 : IN STD_LOGIC; ff_tx_crc_fwd : IN STD_LOGIC; ff_tx_rdy : OUT STD_LOGIC; readdata : OUT STD_LOGIC_VECTOR (31 DOWNTO 0); ena_10 : OUT STD_LOGIC; eth_mode : OUT STD_LOGIC; ff_tx_a_full : OUT STD_LOGIC; ff_tx_a_empty : OUT STD_LOGIC; magic_wakeup : OUT STD_LOGIC; tx_clk : IN STD_LOGIC; m_tx_d2 : OUT STD_LOGIC_VECTOR (3 DOWNTO 0); m_tx_en2 : OUT STD_LOGIC; rx_clk : IN STD_LOGIC; m_rx_d2 : IN STD_LOGIC_VECTOR (3 DOWNTO 0); m_rx_en2 : IN STD_LOGIC ); END tether2; ARCHITECTURE Structural OF tether2 IS constant enableit : STD_LOGIC := '1'; constant disableit : STD_LOGIC := '0'; component tether PORT ( ff_tx_data : IN STD_LOGIC_VECTOR (31 DOWNTO 0); ff_tx_eop : IN STD_LOGIC; ff_tx_err : IN STD_LOGIC; ff_tx_mod : IN STD_LOGIC_VECTOR (1 DOWNTO 0); ff_tx_sop : IN STD_LOGIC; ff_tx_wren : IN STD_LOGIC; ff_tx_clk : IN STD_LOGIC; ff_rx_rdy : IN STD_LOGIC; ff_rx_clk : IN STD_LOGIC; address : IN STD_LOGIC_VECTOR (7 DOWNTO 0); read : IN STD_LOGIC; writedata : IN STD_LOGIC_VECTOR (31 DOWNTO 0); write : IN STD_LOGIC; clk : IN STD_LOGIC; reset : IN STD_LOGIC; gm_rx_d : IN STD_LOGIC_VECTOR (7 DOWNTO 0); gm_rx_dv : IN STD_LOGIC; gm_rx_err : IN STD_LOGIC; m_rx_d : IN STD_LOGIC_VECTOR (3 DOWNTO 0); m_rx_en : IN STD_LOGIC; m_rx_err : IN STD_LOGIC; m_rx_col : IN STD_LOGIC; m_rx_crs : IN STD_LOGIC; tx_clk : IN STD_LOGIC; rx_clk : IN STD_LOGIC; set_10 : IN STD_LOGIC; set_1000 : IN STD_LOGIC; ff_tx_crc_fwd : IN STD_LOGIC; xon_gen : IN STD_LOGIC; xoff_gen : IN STD_LOGIC; magic_sleep_n : IN STD_LOGIC; ff_tx_rdy : OUT STD_LOGIC; ff_rx_data : OUT STD_LOGIC_VECTOR (31 DOWNTO 0); ff_rx_dval : OUT STD_LOGIC; ff_rx_eop : OUT STD_LOGIC; ff_rx_mod : OUT STD_LOGIC_VECTOR (1 DOWNTO 0); ff_rx_sop : OUT STD_LOGIC; rx_err : OUT STD_LOGIC_VECTOR (5 DOWNTO 0); readdata : OUT STD_LOGIC_VECTOR (31 DOWNTO 0); waitrequest : OUT STD_LOGIC; gm_tx_d : OUT STD_LOGIC_VECTOR (7 DOWNTO 0); gm_tx_en : OUT STD_LOGIC; gm_tx_err : OUT STD_LOGIC; m_tx_d : OUT STD_LOGIC_VECTOR (3 DOWNTO 0); m_tx_en : OUT STD_LOGIC; m_tx_err : OUT STD_LOGIC; ena_10 : OUT STD_LOGIC; eth_mode : OUT STD_LOGIC; ff_tx_septy : OUT STD_LOGIC; tx_ff_uflow : OUT STD_LOGIC; ff_tx_a_full : OUT STD_LOGIC; ff_tx_a_empty : OUT STD_LOGIC; rx_err_stat : OUT STD_LOGIC_VECTOR (17 DOWNTO 0); rx_frm_type : OUT STD_LOGIC_VECTOR (3 DOWNTO 0); ff_rx_dsav : OUT STD_LOGIC; ff_rx_a_full : OUT STD_LOGIC; ff_rx_a_empty : OUT STD_LOGIC; magic_wakeup : OUT STD_LOGIC ); end component tether; constant ENABLE_MAGIC_DETECT: integer :=1; constant ENABLE_MDIO: integer :=0; constant ENABLE_SHIFT16: integer :=1; constant ENABLE_SUP_ADDR: integer :=1; constant CRC32GENDELAY: integer :=6; constant MDIO_CLK_DIV: integer :=40; constant ENA_HASH: integer :=1; constant USE_SYNC_RESET: integer :=0; constant STAT_CNT_ENA: integer :=1; constant ENABLE_EXTENDED_STAT_REG: integer :=0; constant ENABLE_HD_LOGIC: integer :=1; constant REDUCED_INTERFACE_ENA: integer :=0; constant CRC32S1L2_EXTERN: integer :=0; constant ENABLE_GMII_LOOPBACK: integer :=1; constant CRC32DWIDTH: integer :=8; constant CUST_VERSION: integer :=0; constant RESET_LEVEL: integer :=1; constant CRC32CHECK16BIT: integer :=0; constant ENABLE_MAC_FLOW_CTRL: integer :=1; constant ENABLE_MAC_TXADDR_SET: integer :=1; constant ENABLE_MAC_RX_VLAN: integer :=1; constant ENABLE_MAC_TX_VLAN: integer :=1; constant SYNCHRONIZER_DEPTH: integer :=4; constant EG_FIFO: integer :=2048; constant EG_ADDR: integer :=11; constant ING_FIFO: integer :=2048; constant ENABLE_ENA: integer :=32; constant ING_ADDR : integer := 11; constant RAM_TYPE: string :="AUTO"; constant INSERT_TA: integer :=0; constant ENABLE_MACLITE: integer :=0; constant MACLITE_GIGE: integer :=0; constant MAX_CHANNELS: integer :=0; -- signal gm_tx_d2 :STD_LOGIC_VECTOR (7 DOWNTO 0) := "00000000"; signal gm_tx_en2 : STD_LOGIC := '0'; signal gm_tx_err2 : STD_LOGIC := '0'; --signal m_tx_d2 : STD_LOGIC_VECTOR (3 DOWNTO 0) := "0000"; --signal m_tx_en2 : STD_LOGIC := '0'; signal m_tx_err2 : STD_LOGIC := '0'; -- signal ff_rx_data : STD_LOGIC_VECTOR (31 DOWNTO 0) := x"00000000"; constant mac_addr : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"10";--"1078D2AD90CB"; -- address of register stored mac address signal ff_tx_mod : STD_LOGIC_VECTOR (1 DOWNTO 0) := "00"; signal rx_err_stat : STD_LOGIC_VECTOR (17 DOWNTO 0) := "000000000000000000"; signal rx_frm_type : STD_LOGIC_VECTOR (3 DOWNTO 0) := "0000"; signal ff_rx_dval2 : STD_LOGIC; signal readdata2 : STD_LOGIC_VECTOR (31 DOWNTO 0); signal waitrequest2 : STD_LOGIC; signal ff_rx_eop : STD_LOGIC; signal rx_err : STD_LOGIC_VECTOR (5 DOWNTO 0); signal ff_rx_sop : STD_LOGIC; signal m_tx_en : STD_LOGIC; signal ff_tx_septy : STD_LOGIC; signal tx_ff_uflow : STD_LOGIC; signal ff_rx_dsav : STD_LOGIC; signal ff_rx_a_full : STD_LOGIC; signal ff_rx_a_empty : STD_LOGIC; signal magic_wakeup2 : STD_LOGIC; BEGIN H2:tether port map ( ff_tx_data => ff_tx_data, ff_tx_eop => ff_tx_eop, ff_tx_err => disableit, ff_tx_mod => ff_tx_mod, ff_tx_sop => ff_tx_sop, ff_tx_wren => ff_tx_wren, ff_tx_clk => ff_tx_clk, ff_rx_rdy => enableit, ff_rx_clk => ff_tx_clk, address => mac_addr, read => read, writedata => writedata, write => write, clk => clk, reset => disableit, gm_rx_d => "00000000", gm_rx_dv => disableit, gm_rx_err => disableit, m_rx_d => m_rx_d2, m_rx_en => m_rx_en2, m_rx_err => disableit, m_rx_col => disableit, m_rx_crs => disableit, tx_clk => tx_clk, rx_clk => tx_clk, set_10 => set_10, set_1000 => set_1000, ff_tx_crc_fwd => disableit, xon_gen => disableit, xoff_gen => disableit, magic_sleep_n => disableit, ff_tx_rdy => ff_tx_rdy, ff_rx_data => ff_rx_data, ff_rx_dval => ff_rx_dval2, ff_rx_eop => ff_rx_eop, ff_rx_mod => ff_tx_mod, ff_rx_sop => ff_rx_sop, rx_err => rx_err, readdata => readdata2, waitrequest => waitrequest2, gm_tx_d => gm_tx_d2, gm_tx_en => gm_tx_en2, gm_tx_err => gm_tx_err2, m_tx_d => m_tx_d2, m_tx_en => m_tx_en, m_tx_err => m_tx_err2, ena_10 => ena_10, eth_mode => eth_mode, ff_tx_septy => ff_tx_septy, tx_ff_uflow => tx_ff_uflow, ff_tx_a_full => ff_tx_a_full, ff_tx_a_empty => ff_tx_a_empty, rx_err_stat => rx_err_stat, rx_frm_type => rx_frm_type, ff_rx_dsav => ff_rx_dsav, ff_rx_a_full => ff_rx_a_full, ff_rx_a_empty => ff_rx_a_empty, magic_wakeup => magic_wakeup ); END Structural; - Altera_Forum
If you are sampling in Signaltap with the same frequency than ENET0_TX_CLK then you won't see it changing in Signaltap, it will be a constant 0 or 1. You need to sample at a higher frequency if you want to see anything on that signal. If you are already sampling at a higher frequency then yes, it means you have a problem with ENET0_TX_CLK.
I didn't get how renaming m_tx_d to m_tx_d2 would avoid any mixups. m_tx_d is an output from the TSE core that needs to be connected to the PHY's MII data input ports. - Altera_Forum
i wrap TSE in tether2 and connect m_tx_d => m_tx_d2 in order to connect less pins in top layer. output m_tx_d do not have any signal
From what I'm seeing tether2 doesn't have a m_tx_d output. So instead of renaming it to m_tx_d2 you could keep the m_tx_d name. But anyway, this isn't related to your problem, it's just a matter of code readability.
yes it has
m_tx_d2 : OUT STD_LOGIC_VECTOR (3 DOWNTO 0); if m_tx_d is not output, why it called tx
