12 years agohttps://skydrive.live.com/redir?resid=e0ed7271c68be47c!350
https://skydrive.live.com/redir?resid=e0ed7271c68be47c!349 i find it that quite easy to get not compatible error or only can run once after press run then stop the result is in above picture, i have edited code, is it connection correct? i am using CLOCK_50, why ENET0_TX_CLK do not have 101010 and only 1 and i begin to confused whether using input or output for some pins where is wrong?LIBRARY ieee;
USE ieee.std_logic_1164.all;
entity Transmit2 is
port (
CLOCK_50 : IN STD_LOGIC;
SW : IN STD_LOGIC_VECTOR(17 DOWNTO 0);
ENET0_TX_CLK : OUT STD_LOGIC;
ENET0_TX_DATA : OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
ENET0_TX_EN : OUT STD_LOGIC;
ENET0_RX_CLK : IN STD_LOGIC;
ENET0_RX_DATA : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
ENET0_RX_DV : IN STD_LOGIC
end entity Transmit2;
architecture syn of Transmit2 is
component tether2 is
port (
ff_tx_data : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
ff_tx_clk : IN STD_LOGIC;
ff_tx_eop : IN STD_LOGIC;
ff_tx_sop : IN STD_LOGIC;
ff_tx_wren : IN STD_LOGIC;
read : IN STD_LOGIC;
writedata : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
write : IN STD_LOGIC;
clk : IN STD_LOGIC;
reset : IN STD_LOGIC;
--tx_clk : IN STD_LOGIC;
set_10 : IN STD_LOGIC;
set_1000 : IN STD_LOGIC;
ff_tx_crc_fwd : IN STD_LOGIC;
ff_tx_rdy : OUT STD_LOGIC;
readdata : OUT STD_LOGIC_VECTOR (31 DOWNTO 0);
ena_10 : OUT STD_LOGIC;
eth_mode : OUT STD_LOGIC;
ff_tx_a_full : OUT STD_LOGIC;
ff_tx_a_empty : OUT STD_LOGIC;
magic_wakeup : OUT STD_LOGIC;
m_tx_d2 : OUT STD_LOGIC_VECTOR (3 DOWNTO 0);
m_tx_en2 : IN STD_LOGIC;
rx_clk : IN STD_LOGIC;
m_rx_d2 : IN STD_LOGIC_VECTOR (3 DOWNTO 0);
m_rx_en2 : IN STD_LOGIC
end component tether2;
signal clk_10 : std_logic;
signal clk_sys : std_logic;
signal pll_locked : std_logic;
signal spi_cs_n : std_logic;
constant whilelooptrue :STD_LOGIC := '1';
constant enableit : STD_LOGIC := '1';
constant disableit : STD_LOGIC := '0';
signal set_10_external : STD_LOGIC;
signal set_100_external : STD_LOGIC;
constant mac: std_logic_vector(47 downto 0) := X"CB90ADD27810";
constant preamble : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"55"; -- 8 bits * 2 = 16, 4 bits one hex
constant SFD : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"D5"; -- 8 bits * 2 = 16
constant dest_mac_addr1 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"10";
constant dest_mac_addr2 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"78";
constant dest_mac_addr3 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"D2";
constant dest_mac_addr4 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"AD";
constant dest_mac_addr5 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"90";
constant dest_mac_addr6 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"CB";
constant src_mac_addr1 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"00";
constant src_mac_addr2 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"12";
constant src_mac_addr3 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"34";
constant src_mac_addr4 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"56";
constant src_mac_addr5 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"78";
constant src_mac_addr6 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"90";
constant payload : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"4B";
constant wholepacketlength1 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"00";
constant wholepacketlength2 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"20";
constant emptyhex : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"00";
constant emptytwobits : STD_LOGIC_VECTOR (1 DOWNTO 0) := "00";
signal tx_data : STD_LOGIC_VECTOR(31 DOWNTO 0);
signal macaddr_data : STD_LOGIC_VECTOR(31 DOWNTO 0);
signal CheckSumResult : STD_LOGIC_VECTOR (31 DOWNTO 0);
signal CheckSumValid : STD_LOGIC;
signal startpacket : STD_LOGIC;
signal endpacket : STD_LOGIC;
signal ff_tx_wren_enable : STD_LOGIC;
signal ff_tx_rdy : STD_LOGIC;
signal ena_10 : STD_LOGIC;
signal eth_mode : STD_LOGIC;
signal ff_tx_a_full : STD_LOGIC;
signal ff_tx_a_empty : STD_LOGIC;
signal magic_wakeup : STD_LOGIC;
signal beginwrite : STD_LOGIC;
begin
H1:tether2 port map (
-- Important connection between output pin and TSE
tx_clk => CLOCK_50,--: IN STD_LOGIC;
m_tx_d2 => ENET0_TX_DATA,--: OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
--m_tx_en2 => ENET0_TX_EN,--: OUT STD_LOGIC
m_tx_en2 => '1',--: OUT STD_LOGIC
rx_clk => ENET0_RX_CLK, --: OUT STD_LOGIC;
m_rx_d2 => ENET0_RX_DATA, --: IN STD_LOGIC_VECTOR(3 DOWNTO 0);
m_rx_en2 => ENET0_RX_DV, --: IN STD_LOGIC;
ff_tx_data => tx_data,
ff_tx_clk => CLOCK_50,
ff_tx_eop => endpacket,
ff_tx_sop => startpacket,
ff_tx_wren => ff_tx_wren_enable,
read => disableit,
writedata => macaddr_data,
write => beginwrite,
clk => CLOCK_50,
reset => disableit,
--tx_clk => CLOCK_50,
set_10 => set_10_external,
set_1000 => set_100_external,
ff_tx_crc_fwd => enableit,
ff_tx_rdy => ff_tx_rdy,
ena_10 => ena_10,
eth_mode => eth_mode, --0 = 10/100Mbps, 1 = 1000Mbps : OUT STD_LOGIC;
ff_tx_a_full => ff_tx_a_full,
ff_tx_a_empty => ff_tx_a_empty,
magic_wakeup => magic_wakeup
process(CLOCK_50)
VARIABLE last_clk : std_logic := '0';
VARIABLE counter : integer := 0;
VARIABLE last_counter : integer := 0;
begin
ENET0_TX_CLK <= CLOCK_50;
if rising_edge(CLOCK_50) then
--if SW(0) = '1' then
if (counter = 0) then
ENET0_TX_EN <= '1';
beginwrite <= '1';
ff_tx_wren_enable <= enableit;
macaddr_data <=mac(31 downto 0);
startpacket <= enableit;
tx_data <= dest_mac_addr1 & dest_mac_addr2 & dest_mac_addr3 & dest_mac_addr4;
end if;
if (counter = 1) then
macaddr_data(15 downto 0) <=mac(47 downto 32);
beginwrite <= '0';
startpacket <= disableit;
tx_data <= dest_mac_addr5 & dest_mac_addr6 & src_mac_addr1 & src_mac_addr2;
end if;
if (counter = 2) then
tx_data <= src_mac_addr3 & src_mac_addr4 & src_mac_addr5 & src_mac_addr6;
end if;
if (counter = 3) then
tx_data <= wholepacketlength1 & wholepacketlength2 & payload & emptyhex;
endpacket <= enableit;
end if;
if (counter >= 4) then
endpacket <= disableit;
ff_tx_wren_enable <= disableit;
beginwrite <= '0';
counter := 0;
end if;
last_counter := counter;
counter := counter + 1;
--else
--beginwrite <= '0';
--end if;
last_clk := CLOCK_50;
end if;
end process;
end architecture syn;
