12 years agoIf you are sampling in Signaltap with the same frequency than ENET0_TX_CLK then you won't see it changing in Signaltap, it will be a constant 0 or 1. You need to sample at a higher frequency if you want to see anything on that signal. If you are already sampling at a higher frequency then yes, it means you have a problem with ENET0_TX_CLK.
I didn't get how renaming m_tx_d to m_tx_d2 would avoid any mixups. m_tx_d is an output from the TSE core that needs to be connected to the PHY's MII data input ports.
