read document again, i change to use 125MHz , still no output and can not see any output when signal analyzer use this signal
LIBRARY ieee; USE ieee.std_logic_1164.all; entity Transmit2 is port ( CLOCK_50 : IN STD_LOGIC; SW : IN STD_LOGIC_VECTOR(17 DOWNTO 0); ENET0_TX_CLK : OUT STD_LOGIC; ENET0_TX_DATA : OUT STD_LOGIC_VECTOR(3 DOWNTO 0); ENET0_TX_EN : OUT STD_LOGIC; ENET0_RX_CLK : IN STD_LOGIC; ENET0_RX_DATA : IN STD_LOGIC_VECTOR(3 DOWNTO 0); ENET0_RX_DV : IN STD_LOGIC ); end entity Transmit2; architecture syn of Transmit2 is component AlteraPLL is PORT ( inclk0 : IN STD_LOGIC; c0 : OUT STD_LOGIC ; c1 : OUT STD_LOGIC ; locked : OUT STD_LOGIC ); end component AlteraPLL; component tether2 is port ( ff_tx_data : IN STD_LOGIC_VECTOR (31 DOWNTO 0); ff_tx_clk : IN STD_LOGIC; ff_tx_eop : IN STD_LOGIC; ff_tx_sop : IN STD_LOGIC; ff_tx_wren : IN STD_LOGIC; read : IN STD_LOGIC; writedata : IN STD_LOGIC_VECTOR (31 DOWNTO 0); write : IN STD_LOGIC; clk : IN STD_LOGIC; reset : IN STD_LOGIC; --tx_clk : IN STD_LOGIC; set_10 : IN STD_LOGIC; set_1000 : IN STD_LOGIC; ff_tx_crc_fwd : IN STD_LOGIC; ff_tx_rdy : OUT STD_LOGIC; readdata : OUT STD_LOGIC_VECTOR (31 DOWNTO 0); ena_10 : OUT STD_LOGIC; eth_mode : OUT STD_LOGIC; ff_tx_a_full : OUT STD_LOGIC; ff_tx_a_empty : OUT STD_LOGIC; magic_wakeup : OUT STD_LOGIC; tx_clk : IN STD_LOGIC; m_tx_d2 : OUT STD_LOGIC_VECTOR (3 DOWNTO 0); m_tx_en2 : IN STD_LOGIC; rx_clk : IN STD_LOGIC; m_rx_d2 : IN STD_LOGIC_VECTOR (3 DOWNTO 0); m_rx_en2 : IN STD_LOGIC ); end component tether2; -- signal clk_10 : std_logic; signal clk_sys : std_logic; signal pll_locked : std_logic; signal spi_cs_n : std_logic; constant whilelooptrue :STD_LOGIC := '1'; constant enableit : STD_LOGIC := '1'; constant disableit : STD_LOGIC := '0'; signal set_10_external : STD_LOGIC; signal set_100_external : STD_LOGIC; constant mac: std_logic_vector(47 downto 0) := X"CB90ADD27810"; constant preamble : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"55"; -- 8 bits * 2 = 16, 4 bits one hex constant SFD : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"D5"; -- 8 bits * 2 = 16 constant dest_mac_addr1 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"10"; constant dest_mac_addr2 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"78"; constant dest_mac_addr3 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"D2"; constant dest_mac_addr4 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"AD"; constant dest_mac_addr5 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"90"; constant dest_mac_addr6 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"CB"; constant src_mac_addr1 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"00"; constant src_mac_addr2 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"12"; constant src_mac_addr3 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"34"; constant src_mac_addr4 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"56"; constant src_mac_addr5 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"78"; constant src_mac_addr6 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"90"; constant payload : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"4B"; constant wholepacketlength1 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"00"; constant wholepacketlength2 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"20"; constant emptyhex : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"00"; constant emptytwobits : STD_LOGIC_VECTOR (1 DOWNTO 0) := "00"; signal tx_data : STD_LOGIC_VECTOR(31 DOWNTO 0); signal macaddr_data : STD_LOGIC_VECTOR(31 DOWNTO 0); signal CheckSumResult : STD_LOGIC_VECTOR (31 DOWNTO 0); signal CheckSumValid : STD_LOGIC; signal startpacket : STD_LOGIC; signal endpacket : STD_LOGIC; signal ff_tx_wren_enable : STD_LOGIC; signal ff_tx_rdy : STD_LOGIC; signal ena_10 : STD_LOGIC; signal eth_mode : STD_LOGIC; signal ff_tx_a_full : STD_LOGIC; signal ff_tx_a_empty : STD_LOGIC; signal magic_wakeup : STD_LOGIC; signal beginwrite : STD_LOGIC; signal clockOneTwoFive : STD_LOGIC; signal clockOneZeroZero : STD_LOGIC; signal clockSixSix : STD_LOGIC; signal clockLocked : STD_LOGIC; begin H2:AlteraPLL port map ( inclk0 => CLOCK_50, --: IN STD_LOGIC; c0 => clockOneTwoFive,--: OUT STD_LOGIC ; c1 => clockOneZeroZero, --: OUT STD_LOGIC ; --c2 => clockSixSix, --: OUT STD_LOGIC ; locked => clockLocked--: OUT STD_LOGIC ); H1:tether2 port map ( -- Important connection between output pin and TSE tx_clk => clockOneTwoFive,--: IN STD_LOGIC; m_tx_d2 => ENET0_TX_DATA,--: OUT STD_LOGIC_VECTOR(3 DOWNTO 0); --m_tx_en2 => ENET0_TX_EN,--: OUT STD_LOGIC m_tx_en2 => '1',--: OUT STD_LOGIC rx_clk => ENET0_RX_CLK, --: OUT STD_LOGIC; m_rx_d2 => ENET0_RX_DATA, --: IN STD_LOGIC_VECTOR(3 DOWNTO 0); m_rx_en2 => ENET0_RX_DV, --: IN STD_LOGIC; -- Important connection between output pin and TSE ff_tx_data => tx_data, ff_tx_clk => clockOneTwoFive, ff_tx_eop => endpacket, ff_tx_sop => startpacket, ff_tx_wren => ff_tx_wren_enable, read => disableit, writedata => macaddr_data, write => beginwrite, clk => clockOneTwoFive, reset => disableit, --tx_clk => clockOneTwoFive, set_10 => set_10_external, set_1000 => set_100_external, ff_tx_crc_fwd => enableit, ff_tx_rdy => ff_tx_rdy, ena_10 => ena_10, eth_mode => eth_mode, --0 = 10/100Mbps, 1 = 1000Mbps : OUT STD_LOGIC; ff_tx_a_full => ff_tx_a_full, ff_tx_a_empty => ff_tx_a_empty, magic_wakeup => magic_wakeup ); process(clockOneTwoFive) VARIABLE last_clk : std_logic := '0'; VARIABLE counter : integer := 0; VARIABLE last_counter : integer := 0; begin ENET0_TX_CLK <= clockOneTwoFive; if rising_edge(clockOneTwoFive) then --if SW(0) = '1' then if (counter = 0) then ENET0_TX_EN <= '1'; beginwrite <= '1'; ff_tx_wren_enable <= enableit; macaddr_data <=mac(31 downto 0); startpacket <= enableit; tx_data <= dest_mac_addr1 & dest_mac_addr2 & dest_mac_addr3 & dest_mac_addr4; end if; if (counter = 1) then macaddr_data(15 downto 0) <=mac(47 downto 32); beginwrite <= '0'; startpacket <= disableit; tx_data <= dest_mac_addr5 & dest_mac_addr6 & src_mac_addr1 & src_mac_addr2; end if; if (counter = 2) then tx_data <= src_mac_addr3 & src_mac_addr4 & src_mac_addr5 & src_mac_addr6; end if; if (counter = 3) then tx_data <= wholepacketlength1 & wholepacketlength2 & payload & emptyhex; endpacket <= enableit; end if; if (counter >= 4) then endpacket <= disableit; ff_tx_wren_enable <= disableit; beginwrite <= '0'; counter := 0; end if; last_counter := counter; counter := counter + 1; --else --beginwrite <= '0'; --end if; last_clk := clockOneTwoFive; end if; end process; end architecture syn; - Altera_Forum
125MHz should only be used with gigabit interfaces. In your case it seems you are using MII in 100Mbit mode so you need 25MHz clocks.
Except for that, it seems that none of the problems I've listed in post# 8 have been addressed. - Altera_Forum
do not know why no output at m_tx_d2 i upload this project, please see anything wrong with it? - Altera_Forum
It seems that none of the problems I've listed in post# 8 have been addressed.
i have already passed data and 25MHz clock for it to output 4 bits data,
why there is no output data? - Altera_Forum
As far as I know you still haven't corrected the problems I talked about, so it's not surprising you don't get any data out of the TSE. The fact that you don't enable the TSE core is the most obvious problem, but of course this doesn't mean you don't have to address the other ones too.
could you tell me which attributes i should care ?
as some enable are output, which attribute are enable? - Altera_Forum
I don't understand your question.
If you are talking about the registers to set in the TSE, I was talking about at least TX_ENA, in my post# 8.
