12 years agoENET0_TX_DATA do not have data to output to my computer, ENET0_TX_CLK do not have signal like clocking 1 0 1 0 ... , why only 1
i prevent mix up with original m_tx_d, so i rename it to indicate which are output pin i guess to input tx_data to ff_tx_data then m_tx_d2 will output to enet0_tx_data, is it correct?LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY tether2 IS
PORT ( ff_tx_data : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
ff_tx_clk : IN STD_LOGIC;
ff_tx_eop : IN STD_LOGIC;
ff_tx_sop : IN STD_LOGIC;
ff_tx_wren : IN STD_LOGIC;
read : IN STD_LOGIC;
writedata : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
write : IN STD_LOGIC;
clk : IN STD_LOGIC;
reset : IN STD_LOGIC;
set_10 : IN STD_LOGIC;
set_1000 : IN STD_LOGIC;
ff_tx_crc_fwd : IN STD_LOGIC;
ff_tx_rdy : OUT STD_LOGIC;
readdata : OUT STD_LOGIC_VECTOR (31 DOWNTO 0);
ena_10 : OUT STD_LOGIC;
eth_mode : OUT STD_LOGIC;
ff_tx_a_full : OUT STD_LOGIC;
ff_tx_a_empty : OUT STD_LOGIC;
magic_wakeup : OUT STD_LOGIC;
m_tx_d2 : OUT STD_LOGIC_VECTOR (3 DOWNTO 0);
m_tx_en2 : OUT STD_LOGIC;
rx_clk : IN STD_LOGIC;
m_rx_d2 : IN STD_LOGIC_VECTOR (3 DOWNTO 0);
m_rx_en2 : IN STD_LOGIC
END tether2;
ARCHITECTURE Structural OF tether2 IS
constant enableit : STD_LOGIC := '1';
constant disableit : STD_LOGIC := '0';
component tether
PORT (
ff_tx_err : IN STD_LOGIC;
ff_tx_mod : IN STD_LOGIC_VECTOR (1 DOWNTO 0);
ff_rx_rdy : IN STD_LOGIC;
ff_rx_clk : IN STD_LOGIC;
address : IN STD_LOGIC_VECTOR (7 DOWNTO 0);
clk : IN STD_LOGIC;
gm_rx_d : IN STD_LOGIC_VECTOR (7 DOWNTO 0);
gm_rx_dv : IN STD_LOGIC;
gm_rx_err : IN STD_LOGIC;
m_rx_d : IN STD_LOGIC_VECTOR (3 DOWNTO 0);
m_rx_en : IN STD_LOGIC;
m_rx_col : IN STD_LOGIC;
m_rx_crs : IN STD_LOGIC;
xon_gen : IN STD_LOGIC;
xoff_gen : IN STD_LOGIC;
magic_sleep_n : IN STD_LOGIC;
ff_rx_data : OUT STD_LOGIC_VECTOR (31 DOWNTO 0);
ff_rx_dval : OUT STD_LOGIC;
ff_rx_eop : OUT STD_LOGIC;
ff_rx_mod : OUT STD_LOGIC_VECTOR (1 DOWNTO 0);
ff_rx_sop : OUT STD_LOGIC;
rx_err : OUT STD_LOGIC_VECTOR (5 DOWNTO 0);
waitrequest : OUT STD_LOGIC;
gm_tx_d : OUT STD_LOGIC_VECTOR (7 DOWNTO 0);
gm_tx_en : OUT STD_LOGIC;
gm_tx_err : OUT STD_LOGIC;
m_tx_d : OUT STD_LOGIC_VECTOR (3 DOWNTO 0);
ff_tx_septy : OUT STD_LOGIC;
tx_ff_uflow : OUT STD_LOGIC;
rx_err_stat : OUT STD_LOGIC_VECTOR (17 DOWNTO 0);
rx_frm_type : OUT STD_LOGIC_VECTOR (3 DOWNTO 0);
ff_rx_dsav : OUT STD_LOGIC;
ff_rx_a_full : OUT STD_LOGIC;
ff_rx_a_empty : OUT STD_LOGIC;
end component tether;
constant ENABLE_MAGIC_DETECT: integer :=1;
constant ENABLE_MDIO: integer :=0;
constant ENABLE_SHIFT16: integer :=1;
constant ENABLE_SUP_ADDR: integer :=1;
constant CRC32GENDELAY: integer :=6;
constant MDIO_CLK_DIV: integer :=40;
constant ENA_HASH: integer :=1;
constant USE_SYNC_RESET: integer :=0;
constant STAT_CNT_ENA: integer :=1;
constant ENABLE_EXTENDED_STAT_REG: integer :=0;
constant ENABLE_HD_LOGIC: integer :=1;
constant REDUCED_INTERFACE_ENA: integer :=0;
constant CRC32S1L2_EXTERN: integer :=0;
constant ENABLE_GMII_LOOPBACK: integer :=1;
constant CRC32DWIDTH: integer :=8;
constant CUST_VERSION: integer :=0;
constant RESET_LEVEL: integer :=1;
constant CRC32CHECK16BIT: integer :=0;
constant ENABLE_MAC_FLOW_CTRL: integer :=1;
constant ENABLE_MAC_TXADDR_SET: integer :=1;
constant ENABLE_MAC_RX_VLAN: integer :=1;
constant ENABLE_MAC_TX_VLAN: integer :=1;
constant SYNCHRONIZER_DEPTH: integer :=4;
constant EG_FIFO: integer :=2048;
constant EG_ADDR: integer :=11;
constant ING_FIFO: integer :=2048;
constant ENABLE_ENA: integer :=32;
constant ING_ADDR : integer := 11;
constant RAM_TYPE: string :="AUTO";
constant INSERT_TA: integer :=0;
constant ENABLE_MACLITE: integer :=0;
constant MACLITE_GIGE: integer :=0;
constant MAX_CHANNELS: integer :=0;
signal gm_tx_d2 :STD_LOGIC_VECTOR (7 DOWNTO 0) := "00000000";
signal gm_tx_en2 : STD_LOGIC := '0';
signal gm_tx_err2 : STD_LOGIC := '0';
--signal m_tx_d2 : STD_LOGIC_VECTOR (3 DOWNTO 0) := "0000";
--signal m_tx_en2 : STD_LOGIC := '0';
signal m_tx_err2 : STD_LOGIC := '0';
signal ff_rx_data : STD_LOGIC_VECTOR (31 DOWNTO 0) := x"00000000";
constant mac_addr : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"10";--"1078D2AD90CB"; -- address of register stored mac address
signal ff_tx_mod : STD_LOGIC_VECTOR (1 DOWNTO 0) := "00";
signal rx_err_stat : STD_LOGIC_VECTOR (17 DOWNTO 0) := "000000000000000000";
signal rx_frm_type : STD_LOGIC_VECTOR (3 DOWNTO 0) := "0000";
signal ff_rx_dval2 : STD_LOGIC;
signal readdata2 : STD_LOGIC_VECTOR (31 DOWNTO 0);
signal waitrequest2 : STD_LOGIC;
signal ff_rx_eop : STD_LOGIC;
signal rx_err : STD_LOGIC_VECTOR (5 DOWNTO 0);
signal ff_rx_sop : STD_LOGIC;
signal m_tx_en : STD_LOGIC;
signal ff_tx_septy : STD_LOGIC;
signal tx_ff_uflow : STD_LOGIC;
signal ff_rx_dsav : STD_LOGIC;
signal ff_rx_a_full : STD_LOGIC;
signal ff_rx_a_empty : STD_LOGIC;
signal magic_wakeup2 : STD_LOGIC;
BEGIN
H2:tether port map (
ff_tx_data => ff_tx_data,
ff_tx_eop => ff_tx_eop,
ff_tx_err => disableit,
ff_tx_mod => ff_tx_mod,
ff_tx_sop => ff_tx_sop,
ff_tx_wren => ff_tx_wren,
ff_tx_clk => ff_tx_clk,
ff_rx_rdy => enableit,
ff_rx_clk => ff_tx_clk,
address => mac_addr,
read => read,
writedata => writedata,
write => write,
clk => clk,
reset => disableit,
gm_rx_d => "00000000",
gm_rx_dv => disableit,
gm_rx_err => disableit,
m_rx_d => m_rx_d2,
m_rx_en => m_rx_en2,
m_rx_col => disableit,
m_rx_crs => disableit,
tx_clk => tx_clk,
rx_clk => tx_clk,
set_10 => set_10,
set_1000 => set_1000,
ff_tx_crc_fwd => disableit,
xon_gen => disableit,
xoff_gen => disableit,
magic_sleep_n => disableit,
ff_tx_rdy => ff_tx_rdy,
ff_rx_data => ff_rx_data,
ff_rx_dval => ff_rx_dval2,
ff_rx_eop => ff_rx_eop,
ff_rx_mod => ff_tx_mod,
ff_rx_sop => ff_rx_sop,
rx_err => rx_err,
readdata => readdata2,
waitrequest => waitrequest2,
gm_tx_d => gm_tx_d2,
gm_tx_en => gm_tx_en2,
gm_tx_err => gm_tx_err2,
m_tx_d => m_tx_d2,
m_tx_en => m_tx_en,
m_tx_err => m_tx_err2,
ena_10 => ena_10,
eth_mode => eth_mode,
ff_tx_septy => ff_tx_septy,
tx_ff_uflow => tx_ff_uflow,
ff_tx_a_full => ff_tx_a_full,
ff_tx_a_empty => ff_tx_a_empty,
rx_err_stat => rx_err_stat,
rx_frm_type => rx_frm_type,
ff_rx_dsav => ff_rx_dsav,
ff_rx_a_full => ff_rx_a_full,
ff_rx_a_empty => ff_rx_a_empty,
magic_wakeup => magic_wakeup
END Structural;
