16 years ago
unsupported type when generating symbol
I successfully compiled and used VHDL code in QII V9.1. Now I want to use the same code multiple times in a higher hierarchy block schematic. So I want to generate a symbol for this VHDL-code.
When trying to generate the symbol, I get an error 10071, meaning I use an unsupported type. And yes, I've defined my own type, but this compiles well in Quartus. Why this error when trying to generate a symbol? Any ideas?
    Just use a VHDL entity/architecture in plain code as your top level, instead of using a graphical tool. You can use a tool such as Sigasi HDT to easily instantiate your components.
    This always works.
    Because the graphic editor in quartus is very limited. It only likes std_logic_vectors.
    Create a new top level VHDL. If its a repeated structure use a generate loop.
    Yes I noticed. It still is strange, because on my VHDL top level I only use type std_logic. My own type is only used inside my VHDL code, which compiles well in Quartus, stand alone.
    Well I've converted my type to std_logic and now it compiles.
    But instead of
    color <= green;
    IF color = green THEN
    I now use
    color < "001";
    IF color = ""001" THEN -- green
    Although I use RTL VHDL, I prefer to use schematic instead of structural VHDL. Thanks for your replies.
    The problem with schematics is that you wont be able to simulate them from Quartus 10+.
    But why dont you just use constants to reference the colours to make it as readable as you had before?
    constant GREEN : std_logic_vector := "001";
    if color = GREEN then
    Hi Tricky,
    Of course you're right.
    This is as readable as my original code.
    Well, it was the first time I used my own types.
    Not very succesfull. Next time I'll stick to std_logic.
    Thanks for the information about Quartus 10+
    --- Quote Start ---
    --- Quote End ---
    or you could continue to use the Create HDL Design File for Current File option.
    learning HDL is a good idea, but there are certainly alternatives for those using .bdf files.
    you could, but you lose all the support for proper typing that VHDL was designed for. you're stuck with std_logic(_vector)!
