Altera_ForumHonored Contributor16 years agounsupported type when generating symbol I successfully compiled and used VHDL code in QII V9.1. Now I want to use the same code multiple times in a higher hierarchy block schematic. So I want to generate a symbol for this VHDL-code. ...Show More
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
