Unable to view Platform Designer generated IP interface and internal signals in Questa Simulation.
I am trying to simulate a RTL design which contains a modular scatter gather DMA (stream to memory-map) IP generated by Quartus Prime Pro platform designer.
- I am able to generate HDL from the platform designer and instantiate it in my test bench.
- I am able to generate Simulator setup Script for IP (for Questa simulator) using GUI without any error / warnings.
While trying to simulate the design (using Quartus Tools -> Run Simulation -> RTL Simulation option), Simulation is running without error. I can see module instances inside the Questa simulator (QuestaIntel FPGA Edition Edition-64 2024.1). But unable to see any interface signals to/from the platform designer generated IPs in the waveform. I can see all the test bench signals and their transitions in the waveform.
Can anybody suggest where I am going wrong or modifications required (if any) to "run_msim_rtl_verilog.do" file ?
Ashish.
May I know do you have any further concern?
Sheng
- ShengN_altera
Since there's a new post on the another problem. I'll reply in that post instead.
Sheng
- ShengN_altera
In Questa, you may go to Simulate -> Design Optimization -> Visibility -> Apply full visibility check screenshot:
Or add set USER_DEFINED_ELAB_OPTIONS -voptargs=+acc in run_msim_rtl_verilog.do file then re-execute the .do file
Sheng
- ShengN_altera
Sheng
- Ashish_Pradhan
Hello ShengN,
Thanks for your suggestion. I am able to simulate it now.
But I observe following problem:
I am trying to simulate an Avalon modular scatter gather DMA (msgdma_0) in Stream to memory map configuration.
I am trying to send descriptor info (providing write address in appropriate field as specified in the user guide, appropriate Byteenable,
& Driving "write" signal high from test bench to the DUT (i.e msgdma_0), through the descriptor channel (msgdma_0_descriptor_slave_write, *_descriptor_slave_writedata, *_descriptor_slave_byteenable).
I am also driving data and valid through "msgdma_0_st_srink_data", "msgdma_0_st_srink_valid" and feed to the DUT(msgdma_0), configured CSR field as per uer guide.Simulation is running properly without any error, I can see all the test bench signals in the waveform as expected.
But I do not see any output coming out from the platform designer generated IP (msgdma_0) in their respective output ports such as (msgdma_0_mm_write_address, *_mm_write_write, *_mm_write_byteenable, *_mm_write_writedata, or *_csr_irq_irq).
Can you pls guide where I am going wrong ? or suggest how can I get the expected behavior of Avalon modular scatter gather DMA.
Ashish.
- ShengN_altera
You may go to Questa sim tab -> right-click the instance -> Add to -> Wave -> All items in region and below
Sheng
- Ashish_Pradhan
Hello Sheng,
Thanks for the reply. Actually my issue is I am unable to see any transition in those out put channels which I mentioned in the previous reply. I can see the channels (msgdma_0_mm_write_address, *_mm_write_write, *_mm_write_byteenable, *_mm_write_writedata, or *_csr_irq_irq) in the waveform window.
To brief the problem:
-I exported CSR, descriptor, st_srink, & mm_write channels. Configure CSR and Descriptor through test bench, & driving data through st_srink, which I can see in the waveform, but I do not see any transition in the msgDMA mm_write output channel.
So could you pls guide me where I am going wrong , and how should I'll able to transfer data in msgDMA in a stream to memory-map configuration ?
Thanks & Regards,
Ashish
