Unable to view Platform Designer generated IP interface and internal signals in Questa Simulation.
- 1 year ago
May I know do you have any further concern?
Sheng
You may go to Questa sim tab -> right-click the instance -> Add to -> Wave -> All items in region and below
Sheng
Hello Sheng,
Thanks for the reply. Actually my issue is I am unable to see any transition in those out put channels which I mentioned in the previous reply. I can see the channels (msgdma_0_mm_write_address, *_mm_write_write, *_mm_write_byteenable, *_mm_write_writedata, or *_csr_irq_irq) in the waveform window.
To brief the problem:
-I exported CSR, descriptor, st_srink, & mm_write channels. Configure CSR and Descriptor through test bench, & driving data through st_srink, which I can see in the waveform, but I do not see any transition in the msgDMA mm_write output channel.
So could you pls guide me where I am going wrong , and how should I'll able to transfer data in msgDMA in a stream to memory-map configuration ?
Thanks & Regards,
Ashish
