Timing Violations in JTAG Signals
I have a Arria10 FPGA design using Platform Desginer which includes a Avalon to JTAG Brdige.
I have added a jtag.sdc file to the project based on this guideline: JTAG Signals
and set all the "--customize here--" sections according to my design (see attached sdc file).
However the Timing Analyzer gives me several setup violations on JTAG signals:
-18.207 auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|jtagpins|int_tdo_reg~LRTM_8 altera_reserved_tdo altera_reserved_tck (INVERTED) altera_reserved_tck (INVERTED) 33.333 -2.582 4.240 Slow 950mV 100C Model -18.206 auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|jtagpins|int_tdo_reg~LRTM_9 altera_reserved_tdo altera_reserved_tck (INVERTED) altera_reserved_tck (INVERTED) 33.333 -2.582 4.239 Slow 950mV 100C Model -18.157 auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|jtagpins|int_tdo_reg~LRTM_7 altera_reserved_tdo altera_reserved_tck (INVERTED) altera_reserved_tck (INVERTED) 33.333 -2.582 4.190 Slow 950mV 100C Model -18.142 auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|jtagpins|int_tdo_reg~LRTM_10 altera_reserved_tdo altera_reserved_tck (INVERTED) altera_reserved_tck (INVERTED) 33.333 -2.582 4.175 Slow 950mV 100C Model -18.123 auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|jtagpins|int_tdo_reg~LRTM_11 altera_reserved_tdo altera_reserved_tck (INVERTED) altera_reserved_tck (INVERTED) 33.333 -2.582 4.156 Slow 950mV 100C Model -18.120 auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|jtagpins|int_tdo_reg~LRTM_6 altera_reserved_tdo altera_reserved_tck (INVERTED) altera_reserved_tck (INVERTED) 33.333 -2.582 4.153 Slow 950mV 100C Model -17.207 auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|jtagpins|int_tdo_reg~LRTM_1 altera_reserved_tdo altera_reserved_tck (INVERTED) altera_reserved_tck (INVERTED) 33.333 -2.125 3.697 Slow 950mV 0C Model -17.136 auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|jtagpins|int_tdo_reg~LRTM_3 altera_reserved_tdo altera_reserved_tck (INVERTED) altera_reserved_tck (INVERTED) 33.333 -2.125 3.626 Slow 950mV 0C Model -17.069 auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|jtagpins|int_tdo_reg~LRTM_2 altera_reserved_tdo altera_reserved_tck (INVERTED) altera_reserved_tck (INVERTED) 33.333 -2.125 3.559 Slow 950mV 0C Model -17.064 auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|jtagpins|int_tdo_reg~LRTM_4 altera_reserved_tdo altera_reserved_tck (INVERTED) altera_reserved_tck (INVERTED) 33.333 -2.125 3.554 Slow 950mV 0C Model -16.972 auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|jtagpins|int_tdo_reg~LRTM altera_reserved_tdo altera_reserved_tck (INVERTED) altera_reserved_tck (INVERTED) 33.333 -2.125 3.462 Slow 950mV 0C Model -16.075 auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|jtagpins|atom_inst|atom~jtag_reg__nff altera_reserved_tdo altera_reserved_tck (INVERTED) altera_reserved_tck (INVERTED) 33.333 -0.450 4.240 Slow 950mV 0C Model
The listed registers look similar but not identical to the security reg listing in the jtag.sdc line 86-89 which are to be ignored.
So I'm not sure if these errors are actual errors caused, e.g. by a too high JTAG clock rate, or if these registers are just missing a respective false path due to encrypted core.
The Timing Analyzer does list the falling paths as encrypted:
Please advise how to deal with these JTAG signal in timing analysis.
Fabian
After internal testing and discussion, we’ve confirmed the following for Arria 10 devices:
- Only the on-board USB-Blaster II is capable of supporting up to 24 MHz.
- The off-board USB-Blaster II cannot reach 24 MHz due to certain limitations
- That said, if the TDO pin of the Arria 10 is driving the TDI of another device through a short trace, it can still support up to 24 MHz.
In the SDC files, you’ll notice a placeholder such as <<customer here>>. This needs to be updated based on the actual trace length measurements on your board. If you're targeting 24 MHz, the timing constraints will need to be tighter to meet the higher frequency requirements.
I'll attach a sample SDC file that helps close timing at higher speeds. Let me know if you have any further questions.
- sstrell
You say jtag.sdc was added to the project, but is it listed in the Timing Analyzer settings in the Settings dialog box? Very common issue to forget to to add that there.
- KennyT_altera
Can you attached your design.qar file to take a look?
- FabianL
The sdc file is active in the project and also in the timing Analyzer settings.
I am sorry, I cannot share my complete project, as it contains Intellectual Property of the company.
The failing paths are explicitly not covered by the .sdc constraint from the Intel Manual:
# Cut a few timing paths that are not related to JTAG logic in # the FPGA core, such as security mode. set_false_path -from [get_ports {altera_reserved_tdi}] -to [get_ports {altera_reserved_tdo}] if { [get_collection_size [get_registers -nowarn *~jtag_reg]] > 0 } { set_false_path -from [get_registers *~jtag_reg] -to [get_ports {altera_reserved_tdo}] }The violations are about the tdo_reg
-18.207 auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|jtagpins|int_tdo_reg~LRTM_8 altera_reserved_tdo altera_reserved_tck (INVERTED) altera_reserved_tck (INVERTED) 33.333 -2.582 4.240 Slow 950mV 100C ModelThe Question is, is this intentional? and how to debug timing issues within an encrypted core?
Or are the tdo_reg constraints missing in the sdc file?
Fabian
- KennyT_altera
1) Can you double check if you have missing constrain by following the below:
https://www.intel.com/content/www/us/en/support/programmable/articles/000092769.html
2) Do you have signal tap added to your design? If yes, can you temporally remove the signal tap and see if there are still timing violation?
- FabianL
1) I did the check with the mentioned sdc template and it matches completely the design .sdc file, except for an assignment which is only valid for Stratix10. Since I'm using Aria 10 this won't be applied.
2) I don't have any signal tap in my design. The only thing I use is JTAG to Avalon Master Bridge Intel FPGA IP Version 19.1 which accesses the main Avalon system bus
best regards
Fabian
- KennyT_altera
Can you temporally try to remove that IP to see if that is the root cause?
- FabianL
I just removed the IP and still have the timing errors.
I also managed to create a very simple example project with basically nothing in it. It also shows timing errors related to JTAG TDO Pins, even though it's about different source nodes. Maybe that helps to analyze the problem.
- KennyT_altera
After running several tests on a smaller design, we observed that violations may occur if Signal Tap has been previously enabled. Once enabled, Quartus tends to retain the configuration and automatically adds an additional module named auto_fab_0. The issue appears to be linked to the encrypted Signal Tap IP.
To address this, please ensure that all constraints are properly defined for your board. You may need to customize the constraint settings accordingly. For reference, Intel provides detailed guidance on JTAG constraints here:
JTAG Constraints File – Timing Analyzer Cookbook If all constraints are correctly applied and aligned with your board configuration, we recommend reducing the operating frequency to 16 MHz as a next step.
Additionally, I will further investigate whether this issue is related to a potential bug in the current version of Quartus by comparing it with older releases. I’ll follow up with more findings soon. Thanks
- FabianL
Yes I can verify, that Quartus has added a module auto_fab_0 to the project, but the signal tap file definitely has been removed.
Is there any possibility to force Quartus to remove all signal tap remnants?
best regards
Fabian
- FabianL
I am a bit confused about the recommended jtag.sdc file:
in the top function set_jtag_timing_constraints the default is to use separate timing constraints for analysis and fitter. As I understand the related comment this is the recommended default:
# If the timing characteristic outside of FPGA is well understood, and # there is a need to provide more slack to allow flexible placement of # JTAG logic in the FPGA core, use the timing constraints for both # timing analysis and fitter; otherwise, use the default fitter timing # constraints. # ---customize here--- set use_fitter_specific_constraint 1However in the set_default_quartus_fit_timing_directive function the JTAG clock is fixed to 33 MHz (which is the max. Arria 10 supports)
proc set_default_quartus_fit_timing_directive { } { # A10 supports max 33.3Mhz clock set jtag_33Mhz_t_period 30 create_clock -name {altera_reserved_tck} -period $jtag_33Mhz_t_period [get_ports {altera_reserved_tck}] set_clock_groups -asynchronous -group {altera_reserved_tck} # Force fitter to place register driving TDO pin to be as close to # the JTAG controller as possible to maximize the slack outside of FPGA. set_max_delay -to [get_ports { altera_reserved_tdo } ] 0 }In the end this gives me the timing errors, even if I change the Blaster frequency to 16 MHz in set_tck_timing_spec
proc set_tck_timing_spec { } { # USB Blaster 1 uses 6 MHz clock = 166.666 ns period set ub1_t_period 166.666 # USB Blaster 2 uses 24 MHz clock = 41.666 ns period set ub2_default_t_period 41.666 # USB Blaster 2 running at 16 MHz clock safe mode = 62.5 ns period set ub2_safe_t_period 62.5 # ---customize here--- set tck_t_period $ub2_safe_t_period create_clock -name {altera_reserved_tck} -period $tck_t_period [get_ports {altera_reserved_tck}] set_clock_groups -asynchronous -group {altera_reserved_tck} }To me it seems strange to have 2 separate constraints for the same clock for analysis and fitter.
- Could you please explain what's the reason for this?
- Is it intended to adjust the clock constraint in set_default_quartus_fit_timing_directive when changing the JTAG Frequency? if yes why is it using separate functions to set the clock. If no then I still have the problem with the timing errors!
Thanks for your help
best regards
Fabian
- KennyT_altera
I will answer the below one by one:
Question:
Is there any way to force Quartus to completely remove all Signal Tap remnants?
Answer:
The most reliable method is to create a new Quartus project from scratch. Gradually import all your source files, settings, and constraints into the fresh project. This ensures that no leftover Signal Tap configurations or hidden assignments carry over.
