Timing Violations in JTAG Signals
- 1 year ago
After internal testing and discussion, we’ve confirmed the following for Arria 10 devices:
- Only the on-board USB-Blaster II is capable of supporting up to 24 MHz.
- The off-board USB-Blaster II cannot reach 24 MHz due to certain limitations
- That said, if the TDO pin of the Arria 10 is driving the TDI of another device through a short trace, it can still support up to 24 MHz.
In the SDC files, you’ll notice a placeholder such as <<customer here>>. This needs to be updated based on the actual trace length measurements on your board. If you're targeting 24 MHz, the timing constraints will need to be tighter to meet the higher frequency requirements.
I'll attach a sample SDC file that helps close timing at higher speeds. Let me know if you have any further questions.
I just removed the IP and still have the timing errors.
I also managed to create a very simple example project with basically nothing in it. It also shows timing errors related to JTAG TDO Pins, even though it's about different source nodes. Maybe that helps to analyze the problem.
