JackDalton's avatar
JackDalton
7 months ago
Timing Violations: 8x F-Tile ETH Hard IP TX_CLKOUT
Hello Intel Team,
In our design, we instantiated eight 10G F-Tile Ethernet Hard IPs (including ANLT) using the VHDL "GENERATE" construct. During timing analysis, we are encountering setup and hold violations on the "TX_CLKOUT" path of the F-Tile transceivers.
The "REPORT_CLOCKS" command shows that these 8 clocks are being generated with a frequency of 402.83 MHz under the following names:
gen_eth[0].proc_ftile_eth_hardip|eth_f_0|tx_clkout|ch23
gen_eth[1].proc_ftile_eth_hardip|eth_f_0|tx_clkout|ch22
gen_eth[7].proc_ftile_eth_hardip|eth_f_0|tx_clkout|ch16
The corresponding master clocks are:
gen_eth[0].proc_ftile_eth_hardip|eth_f_0|tx_pld_pcs_clk_reg|ch23
TX_CLKOUT clocks are asynchronous to each other and operate independently. Therefore, we attempted to exclude them from timing analysis using the "set_clock_groups -asynchronous" constraint, like this:
set_clock_groups -asynchronous \
-group { [get_clocks {gen_eth[0].proc_ftile_eth_hardip|eth_f_0|tx_clkout|ch23}] } \
-group { [get_clocks {gen_eth[1].proc_ftile_eth_hardip|eth_f_0|tx_clkout|ch22}] } \
-group { [get_clocks {gen_eth[2].proc_ftile_eth_hardip|eth_f_0|tx_clkout|ch21}] } \
-group { [get_clocks {gen_eth[3].proc_ftile_eth_hardip|eth_f_0|tx_clkout|ch20}] } \
-group { [get_clocks {gen_eth[4].proc_ftile_eth_hardip|eth_f_0|tx_clkout|ch19}] } \
-group { [get_clocks {gen_eth[5].proc_ftile_eth_hardip|eth_f_0|tx_clkout|ch18}] } \
-group { [get_clocks {gen_eth[6].proc_ftile_eth_hardip|eth_f_0|tx_clkout|ch17}] } \
-group { [get_clocks {gen_eth[7].proc_ftile_eth_hardip|eth_f_0|tx_clkout|ch16}] }
However, this approach results in the following errors:
- Warning(20314): Invalid collection filter: [get_clocks {gen_eth[0].proc...}]
- Warning(332049): Ignored set_clocks_group: Argument -group with value could not match any element of the type clk.
- Warning(332049): Argument -group is not an obejct ID.
I’ve tried multiple approaches, get_nets, Get_pins, also using wildcards and "create_generated_clock", but nothing has resolved the issue.
According to my understanding, a "create_generated_clock" constraint shouldn't be necessary, since these clocks are automatically generated by Quartus.
When inspecting the design in the Timing Analyzer using "get_clocks *ch23, the clock names appear to be internally resolved to autogenerated IDs like "_co15660".
However, these IDs are not stable and may change with each compile (fit), which makes them unsuitable for constraints.
At this point, I am running out of ideas.
  • Question:
    How can I properly constraint or eliminate the setup and hold violations on the eight "TX_CLKout" clocks generated by Quartus in the F-Tile Ethernet Hard IPs?
  • Should I just use "Set_False_Path"?
  • I used the "Generate" command in VHDL to instantiate the 8 F-Tile ETH Hard IP + 8 ANLT. Could be this a problem ?
kind regards
Jacob
  • Hello,
    We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support.
    If you have a new question, feel free to open a new thread to get the support from Intel experts.
    Thank you.
  • Hello,
    • Run report_clocks in the Timing Analyzer GUI.
      • Identify the actual clock names for your 8 TX_CLKOUT clocks.
    • Update your SDC to use the internal names (e.g., _co15660, etc.) in your set_clock_groups constraint.
    • Re-run Timing Analysis.
      • The violations should be gone for cross-domain paths.
    1. If you want a more robust SDC that survives name changes, use wildcards or regular expressions if possible, or group all relevant clocks at once:
        • set_clock_groups -asynchronous -group [get_clocks *_tx_clkout*]
      • No, the VHDL generate statement is not the problem as long as each instance is independent. The issue is the SDC matching, not your VHDL instantiation.
    Hope this helps.
    Pavee
  • JackDalton's avatar
    JackDalton
    is the problem perhaps too obvious ?
    The F-Tile manual couldn't give me any clues.
    What have I missed?
    I would appreciate a quick hint.
    I would also like to add that we are using the Agilex 7 i-series with Quartus 25.1.
    kind regards
    Jack
