Timing analysis - long combinational path
Running Timing Analyzer I get violations due to long combinational paths. Looking at the path in the technology map viewer, it looks like this
leftmost block = registerbank holding a configurable value used by the other two modules
center/rightmost block = two identical modules using the register-value
I can see the long path, but I do not understand why it is implemented like this. Why is the register-value routed through dec_filter:15 to dec_filter:9, and not getting the value directly from the register-bank-module to the left?
Is there anything I can do to force a different implementation?
- cjak
Thanks, but I believe I have tried that too. I still get violations related to the calculations
Is there something fundamental I have misunderstood about FSMs? or maybe Quartus TA?
My FSM now looks like this:
----------------------------------------------------------------------------- -- Filter statemachine -- -- Avoid start filtering in the "middle" of tvalid, if reset is released at a -- bad time => need both negative edge and a positive edge on the next tvalid -- in order to start filtering. ----------------------------------------------------------------------------- p_filter_fsm : process (clk) is begin if rising_edge(clk) then if (rst = '1') then current_state <= IDLE; else current_state <= next_state; end if; end if; end process p_filter_fsm; ----------------------------------------------------------------------------- -- Counters for handling accRAM-accesses during filtering ----------------------------------------------------------------------------- p_filter_fsm_counters : process (clk) is begin if rising_edge(clk) then if (rst = '1') then accRAM_addr_in <= i_config_q_factor_reg(accRAM_addr_in'range) - 1; accRAM_addr_out <= i_config_q_factor_reg(accRAM_addr_out'range) - 1; prev_accRAM_addr_in <= i_config_q_factor_reg(accRAM_addr_in'range) - 1; prev_accRAM_addr_out <= i_config_q_factor_reg(accRAM_addr_out'range) - 1; coef_addr_cnt <= i_config_filterlength_reg(coef_addr_cnt'range) - 1; filtered_accRAM_addr_out <= (others => '0'); decimation_cnt <= (others => '0'); run_filter_cnt <= (others => '0'); sample_in <= (others => '0'); else -- Defaults run_filter_cnt <= (others => '0'); case current_state is when IDLE => prev_accRAM_addr_in <= i_config_q_factor_reg(accRAM_addr_in'range) - 1; prev_accRAM_addr_out <= i_config_q_factor_reg(accRAM_addr_out'range) - 1; accRAM_addr_in <= i_config_q_factor_reg(accRAM_addr_in'range) - 1; accRAM_addr_out <= i_config_q_factor_reg(accRAM_addr_out'range) - 1; coef_addr_cnt <= i_config_filterlength_reg(coef_addr_cnt'range) - 1; decimation_cnt <= (others => '0'); ------------------------------------------------------------------- when NEXT_SAMPLE => accRAM_addr_in <= prev_accRAM_addr_in; accRAM_addr_out <= prev_accRAM_addr_out; if (sample_tvalid_posedge = '1' or sample_tvalid_negedge = '1') then sample_in <= sample_s1.tdata(GC_CH_DATA_WIDTH-1 downto 0); coef_addr_cnt <= coef_addr_cnt - to_integer(i_config_d_factor_reg); decimation_cnt <= decimation_cnt + 1; end if; ------------------------------------------------------------------- when FILTERING => -- Counter for controlling length of Filtering-state run_filter_cnt <= run_filter_cnt + 1; -- Update address-counter for coef-RAM, until last overlap is reached if (run_filter_cnt < i_config_q_factor_reg-1) then if (coef_addr_cnt < i_config_d_factor_reg) then coef_addr_cnt <= i_config_filterlength_reg(coef_addr_cnt'range) - 1; else coef_addr_cnt <= coef_addr_cnt - to_integer(i_config_d_factor_reg); end if; end if; -- Control length of FILTERING-state if (run_filter_cnt = i_config_q_factor_reg+8) then if (decimation_cnt < i_config_d_factor_reg) then coef_addr_cnt <= i_config_filterlength_reg(coef_addr_cnt'range) -1 -decimation_cnt; -- coef in first overlap end if; end if; -- Read previous sum from accRAM if (run_filter_cnt > i_config_q_factor_reg-1) then accRAM_addr_out <= filtered_accRAM_addr_out; elsif (run_filter_cnt > 0) then -- Rotating accRAM-address counter for reading from accRAM if (accRAM_addr_out = 0) then accRAM_addr_out <= i_config_q_factor_reg(accRAM_addr_out'range) - 1; else accRAM_addr_out <= accRAM_addr_out - 1; end if; end if; if (run_filter_cnt > C_START_WRITING_NEW_SUM+1 and run_filter_cnt < C_START_WRITING_NEW_SUM+i_config_q_factor_reg+1) then if (accRAM_addr_in = 0 and we_accRAM = '1') then accRAM_addr_in <= i_config_q_factor_reg(accRAM_addr_in'range) - 1; else accRAM_addr_in <= accRAM_addr_in - 1; end if; end if; ------------------------------------------------------------------- when FILTER_OUTPUT => -- Flush cell which is read, in accRAM accRAM_addr_in <= filtered_accRAM_addr_out; if (i_config_q_factor_reg = 1) then filtered_accRAM_addr_out <= (others => '0'); elsif (filtered_accRAM_addr_out > i_config_q_factor_reg-2) then filtered_accRAM_addr_out <= (others => '0'); else filtered_accRAM_addr_out <= filtered_accRAM_addr_out + 1; end if; -- Update coefficient for next sample coef_addr_cnt <= i_config_filterlength_reg(coef_addr_cnt'range) - 1; -- Reset decimation counter decimation_cnt <= (others => '0'); -- Store accRAM-address value for next round of filtering before -- changing state prev_accRAM_addr_in <= accRAM_addr_in; prev_accRAM_addr_out <= accRAM_addr_out; when others => null; end case; end if; end if; end process p_filter_fsm_counters; ----------------------------------------------------------------------------- -- Asynchronous FSM outputs ----------------------------------------------------------------------------- p_filter_fsm_outputs : process (all) is begin -- Defaults next_state <= current_state; case current_state is when IDLE => next_state <= NEXT_SAMPLE; ------------------------------------------------------------------- when NEXT_SAMPLE => if (sample_tvalid_posedge = '1' or sample_tvalid_negedge = '1') then next_state <= FILTERING; else next_state <= NEXT_SAMPLE; end if; ------------------------------------------------------------------- when FILTERING => -- Control length of FILTERING-state if (run_filter_cnt = i_config_q_factor_reg+8) then if (decimation_cnt < i_config_d_factor_reg) then next_state <= NEXT_SAMPLE; elsif (decimation_cnt = i_config_d_factor_reg) then next_state <= FILTER_OUTPUT; end if; else next_state <= FILTERING; end if; ------------------------------------------------------------------- when FILTER_OUTPUT => next_state <= NEXT_SAMPLE; when others => next_state <= NEXT_SAMPLE; end case; end process p_filter_fsm_outputs; ----------------------------------------------------------------------------- -- FSM pipeline stage ----------------------------------------------------------------------------- p_fsm_pipelining : process (clk) is begin if rising_edge(clk) then if (rst = '1') then accRAM_Re_out_add <= (others => '0'); accRAM_Im_out_add <= (others => '0'); we_accRAM <= '0'; o_filtered_sample.tdata(4*GC_CH_DATA_WIDTH-1 downto 0) <= (others => '0'); o_filtered_sample.tvalid <= '0'; o_filtered_sample.tlast <= '0'; else -- Defaults accRAM_Re_out_add <= accRAM_Re_out; accRAM_Im_out_add <= accRAM_Im_out; we_accRAM <= '0'; o_filtered_sample.tdata(4*GC_CH_DATA_WIDTH-1 downto 0) <= (others => '0'); o_filtered_sample.tvalid <= '0'; o_filtered_sample.tlast <= '0'; case current_state is when IDLE => accRAM_Re_out_add <= (others => '0'); accRAM_Im_out_add <= (others => '0'); o_filtered_sample.tvalid <= '0'; o_filtered_sample.tlast <= '0'; ------------------------------------------------------------------- when FILTERING => -- Add new sum and store in accRAM if (run_filter_cnt > C_START_WRITING_NEW_SUM+i_config_q_factor_reg) then we_accRAM <= '0'; elsif (run_filter_cnt > C_START_WRITING_NEW_SUM) then we_accRAM <= '1'; end if; ------------------------------------------------------------------- when FILTER_OUTPUT => we_accRAM <= '1'; o_filtered_sample.tdata <= accRAM_Re_Out & accRAM_Im_out; o_filtered_sample.tvalid <= '1'; o_filtered_sample.tlast <= '0'; when others => null; end case; end if; end if; end process p_fsm_pipelining; ----------------------------------------------------------------------------- -- Filter-calculations, synchronous ----------------------------------------------------------------------------- p_filter_calculations : process (clk) is begin if rising_edge(clk) then -- Multiplication of input sample with coefficients mult_Re <= std_logic_vector(resize(signed(sample_in) * signed(i_coef_data(2*GC_COEF_DATA_WIDTH-1 downto GC_COEF_DATA_WIDTH)), mult_Re'length)); mult_Im <= std_logic_vector(resize(signed(sample_in) * signed(i_coef_data(GC_COEF_DATA_WIDTH-1 downto 0)), mult_Im'length)); -- Resizing of vectors mult_Re_ext <= std_logic_vector(resize(signed(mult_Re), mult_Re_ext'length)); mult_Im_ext <= std_logic_vector(resize(signed(mult_Im), mult_Im_ext'length)); -- Truncate number of bits defined in 'config_lsb_prod_reg' case i_config_lsb_prod_reg(2 downto 0) is when b"001" => add_Re_in <= mult_Re_ext(GC_ADDER_WIDTH downto 1); -- (36:1) add_Im_in <= mult_Im_ext(GC_ADDER_WIDTH downto 1); when b"010" => add_Re_in <= mult_Re_ext(GC_ADDER_WIDTH+1 downto 2); -- (37:2) add_Im_in <= mult_Im_ext(GC_ADDER_WIDTH+1 downto 2); when b"011" => add_Re_in <= mult_Re_ext(GC_ADDER_WIDTH+2 downto 3); -- (38:3) add_Im_in <= mult_Im_ext(GC_ADDER_WIDTH+2 downto 3); when b"100" => add_Re_in <= mult_Re_ext(GC_ADDER_WIDTH+3 downto 4); -- (39:4) add_Im_in <= mult_Im_ext(GC_ADDER_WIDTH+3 downto 4); when others => add_Re_in <= mult_Re_ext(GC_ADDER_WIDTH-1 downto 0); -- same as (b"000") add_Im_in <= mult_Im_ext(GC_ADDER_WIDTH-1 downto 0); end case; -- Add new sum and store in accRAM if (run_filter_cnt > C_START_WRITING_NEW_SUM and run_filter_cnt < C_START_WRITING_NEW_SUM+i_config_q_factor_reg+1) then accRAM_Re_in <= std_logic_vector(signed(add_Re_in) + signed(accRAM_Re_out_add)); accRAM_Im_in <= std_logic_vector(signed(add_Im_in) + signed(accRAM_Im_out_add)); elsif (next_state = FILTER_OUTPUT) then accRAM_Re_in <= (others => '0'); accRAM_Im_in <= (others => '0'); end if; end if; end process p_filter_calculations;- ShengN_altera
Does your problem resolved? Do you need further help? If yes, possible provide your project file?
- cjak
No, I have not achieved timing closure, and the redesigned filter seem to achieve a lower fmax than the original implementation. Unfortunately I cannot share the design.
- ShengN_altera
Could you try retime stage report and fast forward timing closure report for the path that need register check below:
- cjak
I use Quartus Prime Lite Edition. I suspect I do not have access to the reports mentioned?
- cjak
Hi, I rewrote my state-machine, but I did not achieve much increase in performance.
Adding multicycle-path statement on a "semi-static" configuration-registers caused the Fmax to go up, but I still have violations related to the filter. The calculations have been extracted from the state-machine as shown in the code below.
The timing analyzer still complains about long combinational paths. The process below calculates on every clock-cycle. Would it be a solution to added extra pipeline-registers in between the calculation stages, and add multicycle-statements to relax the timing requirement?
p_filter_calculations : process (clk) is begin if rising_edge(clk) then -- Multiplication of input sample with coefficients mult_Re <= std_logic_vector(resize(signed(sample_in) * signed(i_coef_data(2*GC_COEF_DATA_WIDTH-1 downto GC_COEF_DATA_WIDTH)), mult_Re'length)); mult_Im <= std_logic_vector(resize(signed(sample_in) * signed(i_coef_data(GC_COEF_DATA_WIDTH-1 downto 0)), mult_Im'length)); mult_Re_ext <= std_logic_vector(resize(signed(mult_Re), mult_Re_ext'length)); mult_Im_ext <= std_logic_vector(resize(signed(mult_Im), mult_Im_ext'length)); -- Truncate number of bits defined in 'config_lsb_prod_reg' case i_config_lsb_prod_reg(2 downto 0) is when b"000" => add_Re_in <= mult_Re_ext(GC_ADDER_WIDTH-1 downto 0); -- (35:0) add_Im_in <= mult_Im_ext(GC_ADDER_WIDTH-1 downto 0); when b"001" => add_Re_in <= mult_Re_ext(GC_ADDER_WIDTH downto 1); -- (36:1) add_Im_in <= mult_Im_ext(GC_ADDER_WIDTH downto 1); when b"010" => add_Re_in <= mult_Re_ext(GC_ADDER_WIDTH+1 downto 2); -- (37:2) add_Im_in <= mult_Im_ext(GC_ADDER_WIDTH+1 downto 2); when b"011" => add_Re_in <= mult_Re_ext(GC_ADDER_WIDTH+2 downto 3); -- (38:3) add_Im_in <= mult_Im_ext(GC_ADDER_WIDTH+2 downto 3); when b"100" => add_Re_in <= mult_Re_ext(GC_ADDER_WIDTH+3 downto 4); -- (39:4) add_Im_in <= mult_Im_ext(GC_ADDER_WIDTH+3 downto 4); when others => add_Re_in <= mult_Re_ext(GC_ADDER_WIDTH-1 downto 0); -- same as (b"000") add_Im_in <= mult_Im_ext(GC_ADDER_WIDTH-1 downto 0); end case; -- Add new sum and store in accRAM if (run_filter_cnt > C_START_WRITING_NEW_SUM and run_filter_cnt < C_START_WRITING_NEW_SUM+i_config_q_factor_reg+1) then accRAM_Re_in <= std_logic_vector(signed(add_Re_in) + signed(accRAM_Re_out_add)); accRAM_Im_in <= std_logic_vector(signed(add_Im_in) + signed(accRAM_Im_out_add)); elsif (next_state = FILTER_OUTPUT) then accRAM_Re_in <= (others => '0'); accRAM_Im_in <= (others => '0'); end if; end if; end process p_filter_calculations;- ShengN_altera
It's better to add some pipeline register in the state machine. Too high logic level combinational path is not recommended for high performance design because combinational path cannot be retimed.
I think timing will improve a lot after adding pipeline register.
- ShengN_altera
Try to add more pipeline register to shorten the combinational path
- cjak
Thanks for the feedback. I will look into rewriting the statemachine next week.
But, how do you go about to avoid type-casting/conversion like to_integer/signed?
- sstrell
That may not necessarily be the issue. Try cleaning up your state machine first.
- sstrell
A few things.
You have way too much logic in your state machine. The next state logic should simply determine the conditions for switching state (determined in separate processes or elsewhere) and specify what the next state should be. Setting outputs in particular states should be in their own separate non-clocked process so the appropriate output appears as soon as you move to the new state. If you're reliant on some logic within a state to then determine a new value before then assigning an output, that's going to cause timing issues. Create additional states to give yourself extra clock cycles or pull that logic out. Assignments like these that rely on other logic within the same filtering state are probably the issue and should be in separate combinatorial processes:
Sticking to_integer and signed functions in there doesn't help matters either.
- cjak
Yes, this is the filter. Both multiply and accumulate happens in the FILTERING-state, along with truncation. In addition, there is a RAM holding the accumulated sum. Input-samples are not stored when coming in.
o_coef_addr <= std_logic_vector(coef_addr_cnt); -- Accumulator RAM p_accRAM : process (clk) is begin if rising_edge(clk) then if (we_accRAM = '1') then accRAM_Re(to_integer(accRAM_addr_in)) <= accRAM_Re_in; accRAM_Im(to_integer(accRAM_addr_in)) <= accRAM_Im_in; end if; accRAM_Re_out <= accRAM_Re(to_integer(accRAM_addr_out)); accRAM_Im_out <= accRAM_Im(to_integer(accRAM_addr_out)); end if; end process p_accRAM; -- Sample input-samples and detect tvalid-flanks p_edge : process (clk) is begin if rising_edge(clk) then sample_s1.tvalid <= i_sample.tvalid; sample_s1.tdata <= i_sample.tdata; if (i_sample.tvalid = '1' and sample_s1.tvalid = '0') then sample_tvalid_posedge <= '1'; sample_tvalid_negedge <= '0'; elsif (i_sample.tvalid = '0' and sample_s1.tvalid = '1') then sample_tvalid_negedge <= '1'; sample_tvalid_posedge <= '0'; else sample_tvalid_posedge <= '0'; sample_tvalid_negedge <= '0'; end if; end if; end process p_edge; - sstrell
This code isn't showing any of the signal processing from your screenshot. Where is dec_filter?
- cjak
p_filter_fsm : process (clk) is begin if rising_edge(clk) then if (rst = '1') then coef_addr_cnt <= i_config_filterlength_reg(coef_addr_cnt'range) - 1; decimation_cnt <= (others => '0'); accRAM_addr_in <= i_config_q_factor_reg(accRAM_addr_in'range) - 1; prev_accRAM_addr_in <= i_config_q_factor_reg(accRAM_addr_in'range) - 1; accRAM_addr_out <= i_config_q_factor_reg(accRAM_addr_out'range) - 1; prev_accRAM_addr_out <= i_config_q_factor_reg(accRAM_addr_out'range) - 1; run_filter_cnt <= (others => '0'); we_accRAM <= '0'; accRAM_Re_out_add <= (others => '0'); accRAM_Im_out_add <= (others => '0'); filtered_accRAM_addr_out <= (others => '0'); o_filtered_sample.tvalid <= '0'; o_filtered_sample.tlast <= '0'; state_filter <= NEXT_SAMPLE; else -- Defaults accRAM_Re_out_add <= accRAM_Re_out; accRAM_Im_out_add <= accRAM_Im_out; we_accRAM <= '0'; o_filtered_sample.tdata(4*GC_CH_DATA_WIDTH-1 downto 0) <= (others => '0'); o_filtered_sample.tvalid <= '0'; o_filtered_sample.tlast <= '0'; -- FSM case state_filter is ------------------------------------------------------------------- when NEXT_SAMPLE => accRAM_addr_in <= prev_accRAM_addr_in; accRAM_addr_out <= prev_accRAM_addr_out; run_filter_cnt <= (others => '0'); we_accRAM <= '0'; if (sample_tvalid_posedge = '1') then sample_in <= sample_s1.tdata(GC_CH_DATA_WIDTH-1 downto 0); coef_addr_cnt <= coef_addr_cnt - to_integer(i_config_d_factor_reg); decimation_cnt <= decimation_cnt + 1; state_filter <= FILTERING; end if; ------------------------------------------------------------------- when FILTERING => mult_Re <= std_logic_vector(resize(signed(sample_in) * signed(i_coef_data(2*GC_COEF_DATA_WIDTH-1 downto GC_COEF_DATA_WIDTH)), mult_Re'length)); mult_Im <= std_logic_vector(resize(signed(sample_in) * signed(i_coef_data(GC_COEF_DATA_WIDTH-1 downto 0)), mult_Im'length)); mult_Re_ext <= std_logic_vector(resize(signed(mult_Re), mult_Re_ext'length)); mult_Im_ext <= std_logic_vector(resize(signed(mult_Im), mult_Im_ext'length)); -- Truncate number of bits defined in 'config_lsb_prod_reg' case i_config_lsb_prod_reg(2 downto 0) is when b"000" => add_Re_in <= mult_Re_ext(GC_ADDER_WIDTH-1 downto 0); -- (35:0) add_Im_in <= mult_Im_ext(GC_ADDER_WIDTH-1 downto 0); when b"001" => add_Re_in <= mult_Re_ext(GC_ADDER_WIDTH downto 1); -- (36:1) add_Im_in <= mult_Im_ext(GC_ADDER_WIDTH downto 1); when b"010" => add_Re_in <= mult_Re_ext(GC_ADDER_WIDTH+1 downto 2); -- (37:2) add_Im_in <= mult_Im_ext(GC_ADDER_WIDTH+1 downto 2); when b"011" => add_Re_in <= mult_Re_ext(GC_ADDER_WIDTH+2 downto 3); -- (38:3) add_Im_in <= mult_Im_ext(GC_ADDER_WIDTH+2 downto 3); when b"100" => add_Re_in <= mult_Re_ext(GC_ADDER_WIDTH+3 downto 4); -- (39:4) add_Im_in <= mult_Im_ext(GC_ADDER_WIDTH+3 downto 4); when others => add_Re_in <= mult_Re_ext(GC_ADDER_WIDTH-1 downto 0); -- same as (b"000") add_Im_in <= mult_Im_ext(GC_ADDER_WIDTH-1 downto 0); end case; -- Counter for controlling length of Filtering-state run_filter_cnt <= run_filter_cnt + 1; -- Read previous sum from accRAM if (run_filter_cnt > i_config_q_factor_reg-1) then accRAM_addr_out <= filtered_accRAM_addr_out; elsif (run_filter_cnt > 0) then -- Rotating accRAM-address counter for reading from accRAM if (accRAM_addr_out = 0) then accRAM_addr_out <= i_config_q_factor_reg(accRAM_addr_out'range) - 1; else accRAM_addr_out <= accRAM_addr_out - 1; end if; end if; -- Add new sum and store in accRAM if (run_filter_cnt > C_START_WRITING_NEW_SUM+i_config_q_factor_reg) then we_accRAM <= '0'; elsif (run_filter_cnt > C_START_WRITING_NEW_SUM) then we_accRAM <= '1'; accRAM_Re_in <= std_logic_vector(signed(add_Re_in) + signed(accRAM_Re_out_add)); accRAM_Im_in <= std_logic_vector(signed(add_Im_in) + signed(accRAM_Im_out_add)); if (run_filter_cnt > C_START_WRITING_NEW_SUM+1) then -- Rotating accRAM-address counter for writing to accRAM if (accRAM_addr_in = 0 and we_accRAM = '1') then accRAM_addr_in <= i_config_q_factor_reg(accRAM_addr_in'range) - 1; else accRAM_addr_in <= accRAM_addr_in - 1; end if; end if; end if; -- Update address-counter for coef-RAM, until last overlap is reached if (run_filter_cnt < i_config_q_factor_reg-1) then if (coef_addr_cnt < i_config_d_factor_reg) then coef_addr_cnt <= i_config_filterlength_reg(coef_addr_cnt'range) - 1; else coef_addr_cnt <= coef_addr_cnt - to_integer(i_config_d_factor_reg); end if; end if; -- Control length of FILTERING-state if (run_filter_cnt = i_config_q_factor_reg+8) then if (decimation_cnt < i_config_d_factor_reg) then coef_addr_cnt <= i_config_filterlength_reg(coef_addr_cnt'range) -1 -decimation_cnt; -- coef in first overlap state_filter <= NEXT_SAMPLE; elsif (decimation_cnt = i_config_d_factor_reg) then state_filter <= FILTER_OUTPUT; end if; end if; ------------------------------------------------------------------- when FILTER_OUTPUT => o_filtered_sample.tdata <= accRAM_Re_Out & accRAM_Im_out; o_filtered_sample.tvalid <= '1'; o_filtered_sample.tlast <= '0'; if (i_config_q_factor_reg = 1) then filtered_accRAM_addr_out <= (others => '0'); elsif (filtered_accRAM_addr_out > i_config_q_factor_reg-2) then filtered_accRAM_addr_out <= (others => '0'); else filtered_accRAM_addr_out <= filtered_accRAM_addr_out + 1; end if; -- Flush cell which is read, in accRAM we_accRAM <= '1'; accRAM_addr_in <= filtered_accRAM_addr_out; accRAM_Re_in <= (others => '0'); accRAM_Im_in <= (others => '0'); -- Update coefficient for next sample coef_addr_cnt <= i_config_filterlength_reg(coef_addr_cnt'range) - 1; -- Reset decimation counter decimation_cnt <= (others => '0'); -- Store accRAM-address value for next round of filtering before -- changing state prev_accRAM_addr_in <= accRAM_addr_in; prev_accRAM_addr_out <= accRAM_addr_out; state_filter <= NEXT_SAMPLE; when others => state_filter <= NEXT_SAMPLE; end case; end if; end if; end process p_filter_fsm;Here are the filter statemachin which uses the config_q_factor:
- sstrell
Without seeing the code and just going by the names on the logic, you're performing a number of math operations and comparisons on the source signal, adding additional levels of logic. Reviewing and adjusting the RTL code would probably be the easiest solution. Post some code.
