The quartus license works with version 25.0 but not with version 17.0
I recently purchased a Quartus license.
Unfortunately, it works with Quartus version 25.0, but not with version 17.0.
Is there a solution for this?
Thank you in advance
Beroual
- Beroual
version 23.1 It behaves like version 17.0 also
- ShengN_altera
Please use the latest version 25.1.
Legacy version need legacy license (most of them are obsolete already)
- Beroual
for my project:
Using version 25.1 requires some adjustments.
I need version 17.0, which doesn't require any adjustments.
- ShengN_altera
Nios II you can get from Altera SSLC:
Triple speed ethernet license you may need to approach regional distributor for that IP license
- sstrell
It's not clear what the issue is. Can you not use Quartus 25.1?
- Beroual
Hello
I tried to open the exemple in the source
"Detailed Description • Arria® 10 FPGA – Simple Socket Server for the Nios® V/m Processor Design Example • Altera Documentation and Resources Center"
The example file "top.par"
But unfortunately, I couldn't open it
I keep getting the message: "Design template installation failed."
is there any solution? Thanks in advance.
- ShengN_altera
Make sure use the supported version for the example design
- Beroual
For my projects
I need version 17.0, which requires no adjustments.
- ShengN_altera
How about 18.0? Can work?
