15 years ago
Splitting SOPC DDR2 control signals to top and bot- cyclone III
Hi all,
I want to use onboard DDR2 SDRAMs on Cyclone 3 development kit (i want to use 64 bit). I designed all SOPC stuff with DQ width 64 (I changed DQ width in modify parameters option of DDR2 sdram controller to 64 in SOPC). I have two questions:
1)Local interface width became 128 after I changed DQ width to 64 in SOPC. Is this what I might wanna see?
2) This is the more crucial question. SOPC module has only one output for each control signal (cas, ras, cs, etc.). When tried to split them in the top module, I get error saying signal-splitters have invalid fanouts. How can I distribute the output control signals to bot and top banks, or is there a way to make SOPC output two of them ?
Pls. try to explain clearly the advanced statements, I am new in Quartus :)
