10 years agoSimplest method to transmit a file to FPGA
Provided that one has a file that is to be transmitted down to the FPGA and it will store every byte into internal or external memory (maximum size is around 1MegaByte). What is the preferred way of doing this?
Should one create a custom solution in whic the user sends the file down serial port from PC, the FPGA recieves it into a FIFO and then it stores it in internal/external memory on a per-byte or per-byte-block basis. Or is it possible to utilize the JTAG port for this purpose such that the file can be streamed down the JTAG port and the design inside the FPGA can process the bytes as stated above? I expected this to be a simple problem since we already transmit configuration data to the FPGA and possibly a connected configuration memory device. However, it seems that it is not. :|
