10 years agoSimplest method to transmit a file to FPGA
Provided that one has a file that is to be transmitted down to the FPGA and it will store every byte into internal or external memory (maximum size is around 1MegaByte). What is the preferred way of ...
10 years agoOn a second thought, as far as I vaguely understand, there is also a method by which such extra data can be bundled together with the FPGA configuration data and together with this configuration data be burned onto a configuration memory. Perhaps this will be a faster way to get this data onto a flash so the design can read it out and send it to the data converters?
