10 years agoSimplest method to transmit a file to FPGA
Provided that one has a file that is to be transmitted down to the FPGA and it will store every byte into internal or external memory (maximum size is around 1MegaByte). What is the preferred way of ...
10 years agoPCIe would be the obvious choice, but that's complicated and potentially expensive if you're not using a device that has the hard PCIe IP built in. For simple and cheap you can't beat a UART. In this case you can't read the file out of PC memory, you would need an application on the PC transferring the file to you using the UART. But you can use terminal emulators like Teraterm to do this. UARTs are slow, but pretty darn easy to implement and to debug. You can at least star there to get the ball rolling and then upgrade to improve performance as needed.
Bob
