10 years agoSimplest method to transmit a file to FPGA
Provided that one has a file that is to be transmitted down to the FPGA and it will store every byte into internal or external memory (maximum size is around 1MegaByte). What is the preferred way of ...
10 years agoHey Todd -
It would not be difficult at all to do this without a NIOS, but do what you're most comfortable with. You'll want to transfer the file in binary mode. If you have the NIOS you might want to write some code to write a test pattern image to memory so you can test the display path before pulling in live images from the PC. Debugging one piece at a time is always easier. And get familiar with SignalTap if you're not yet. It's a great debug tool (in support of simulation). Good luck! Bob
