10 years agoSimplest method to transmit a file to FPGA
Provided that one has a file that is to be transmitted down to the FPGA and it will store every byte into internal or external memory (maximum size is around 1MegaByte). What is the preferred way of ...
10 years agoHi Xaui, I am searching for an answer to this same question. In particular, Altera's Frame Reader VIP IP core accesses an image stored in SDRAM. It's likely that anyone implementing a circuit including that Frame Reader might have wanted to copy a BMP or TIF from the PC's file system into SDRAM. I would expect there to be an out-of-the-box solution by now. Have you found a good answer? Hopeful thanks ...
