9 years ago
SignalTap II issue
Here is debounce state machine:
module debounce_explicit(input clk, reset, sw, output reg db_level, db_tick);    //symbolic state declaration
    localparam
        zero =    2'b00,
        wait0 =    2'b10,
        one =     2'b11,
        wait1 =    2'b01;
    // number of counter bits (2'N * 20ns = 40ms)
    localparam N = 21;
    //localparam N = 15;
    // signal declaration
    reg  state_reg, state_next;
    reg  q_reg;
    wire  q_next;
    wire q_zero;
    reg q_load, q_dec;
    // FSMD state & data registers
    always @(posedge clk, posedge reset)
        if (reset)
            begin
                state_reg <= zero;
                q_reg <= 0;
            end
        else
            begin
                state_reg <= state_next;
                q_reg <= q_next;
            end
    // FSMD data path (counter) next—state logic
    assign q_next = (q_load) ? {N{1'b1}} : ((q_dec) ? q_reg - 1 : q_reg);
    // status signal
    assign q_zero = (q_next == 0);
    // FSMD control path next—state logic
    always @*
        begin
            state_next = state_reg;    // default state: the same
            q_load =     1'b0;         // default output: 0
            q_dec =        1'b0;         // default output: 0
            db_tick =     1'b0;         // default output: 0
            case (state_reg)
                zero:
                    begin
                        db_level = 1'b0;
                        if (sw)
                            begin
                                state_next = wait1;
                                q_load = 1'b1;
                            end
                    end
                wait1:
                    begin
                        db_level = 1'b0;
                        if (sw)
                            begin
                                q_dec = 1'b1;
                                if (q_zero)
                                    begin
                                        state_next = one;
                                        db_tick = 1'b1;
                                    end
                            end
                        else    // sw==0
                            state_next = zero;
                    end
                one:
                    begin
                        db_level = 1'b1;
                        if (~sw)
                            begin
                                state_next = wait0;
                                q_load = 1'b1;
                            end
                    end
                wait0:
                    begin
                        db_level = 1'b1;
                        if (~sw)
                            begin
                                q_dec = 1'b1;
                                if (q_zero)    state_next = zero;
                            end
                        else    // sw==l
                            state_next = one;
                    end
                default: state_next = zero;
            endcase
        end
endmodule
And here is SignalTap simulation
http://www.alteraforum.com/forum/attachment.php?attachmentid=13218&stc=1
After 2st firing of the input sw the "state machine" frozes definitely in "00" state.
Moreover, after 1st sw firing, the "state machine" value is displayed in symbolic interpretation in SignalTap II, i.e. zero, wait0, one, wait1.
After 2nd sw firing this symbolic interpretation disappears ... leaving place to numeric interpretation, i.e. 0 (as shown on the above image).
So I have 2 questions:
  • why symbolic interpretation disappears
  • is it possible to put into SignalTap the signals that present in the source code in order to debug "system machine" misbehavior. Actually only few signals are available for SignalTap.
Thanks in advance
