WShep1's avatar
WShep1
2 years ago
Signals(nodes) in Signal Tap Node Window Disappear
All of a sudden, the signals in in the Signal Window started disappearing whenever I change the view from "Data" to "Setup" or vica versa. I can get them to reappear by going down tothe "Hierarchy Display" window a clicking the box for the module that the signals are from. For example, if I have selected signals from and module called "mono_out", there is a "mono_out" entry in the "Hierarchy Display" window with a check box next to it. If this box is checked the signals from the "mono_out" module show up in the Signal Window. This box now always gets unchecked when I switch between "Data" and "Setup" and the corresponding signals disappear in the Signal Window. This did not happen until today when I switched to Quartus Prime Version 22.1std.2. How do I stop this from happening?
