WShep1
Contributor
3 years agoSignals(nodes) in Signal Tap Node Window Disappear
All of a sudden, the signals in in the Signal Window started disappearing whenever I change the view from "Data" to "Setup" or vica versa. I can get them to reappear by going down tothe "Hierarchy D...
RichardT_altera
2 years agoI am using Quartus Standard 22.1.2 Build 922 but I'm not able to duplicate the issue.
I'll arrange a team meeting with you through email; please check for an email from me.
Prior to the call, could you please try the troubleshooting steps to eliminate any potential root causes:
- Try disabling any antivirus or firewall software temporarily, as they may be interfering with Quartus.
- Restart Quartus and your computer. This can help clear any temporary issues that may be causing the error.
- Verify that Quartus is installed with all the devices.
- Run Quartus as an administrator
Richard Tan
