WShep1
Contributor
3 years agoSignals(nodes) in Signal Tap Node Window Disappear
All of a sudden, the signals in in the Signal Window started disappearing whenever I change the view from "Data" to "Setup" or vica versa. I can get them to reappear by going down tothe "Hierarchy D...
RichardT_altera
3 years agoCould you try to re-create the .stp file and see if the issue still persists?
Richard Tan
- WShep13 years ago
Contributor
I tried creating a brand new *.stp file, and I get the same results. Hence, if there is a problem with the *.stp file then it is a problem that comes with a newly created *.stp file.
I thought that I had replied with the above comment, but I guess it never got sent as a reply. I am still awaiting an answer to this question as it is still happening and I n=have not received an answer that stops the signals from disappearing. Hence, I would like to reopen this case and keep it open until I get an answer. I am not sure how to reopen this case. I tried but was not able to do so.
