Signals(nodes) in Signal Tap Node Window Disappear
We noticed that we haven't received a response from you regarding the latest previous question/reply/answer, and will now transition your inquiry to our community support. We apologize for any inconvenience this may cause and we appreciate your understanding. If you have any further questions or concerns, please don't hesitate to let us know. Thank you for reaching out to us!
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
- FvM3 years ago
I want to confirm that Signaltap was updated with new features that are not necessarily helpful, at least when you aren't aware of it.
I'm presently working with 22.4 Pro in a bigger project.
1. I also experienced the said the "disappearing" nodes (automatically disabled in hierarchy display), but didn't yet fully understand if it's a bug or feature.
2. More annoying, I repeatedly found newly added nodes hidden somewhere inside an existing data structure. I learned to consider carefully which line has the focus before adding new nodes. If I forgot to do so, I better go back to a safety copy than start searching the hidden nodes...
I believe it's intended as feature, definitely it never happened in older Signaltap versions.
Not specific to new version, a wrong mouse move sometimes makes Signaltap crash, e.g. when editing alias fields.
Nevertheless I love the powerful tool.- WShep13 years ago
Contributor
Thank you for your response. Your response makes much more sense than any of the other responses from Intel employees. I expected that this was a bug (or as you say - a new feature). I to love Signal Tap, but it is very frustrating when it crashes or adds a new feature that cause one hours of time trying to figure out what is happening.
- WShep13 years ago
Contributor
I tried creating a brand new *.stp file, and I get the same results. Hence, if there is a problem with the *.stp file then it is a problem that comes with a newly created *.stp file.
I thought that I had replied with the above comment, but I guess it never got sent as a reply. I am still awaiting an answer to this question as it is still happening and I n=have not received an answer that stops the signals from disappearing. Hence, I would like to reopen this case and keep it open until I get an answer. I am not sure how to reopen this case. I tried but was not able to do so.
