WShep1
Contributor
3 years agoSignals(nodes) in Signal Tap Node Window Disappear
All of a sudden, the signals in in the Signal Window started disappearing whenever I change the view from "Data" to "Setup" or vica versa. I can get them to reappear by going down tothe "Hierarchy D...
sstrell
3 years agoHave you tried saving the .stp file when the box is checked and then closing and reopening the .stp file to see if it now sticks?
I've never seen that happen. If it continues, it's possible the .stp file is corrupted somehow.
