13 years ago
Signal output cannot be synthesized, bad synchronous description.
Hi ,
I have been using vhdl programming for my project and I am trying to make a counter to count clock signal(clk_plstr),the counter is reset with another pulse signal(plsrep in my code).
I am successful in simulating the code but while I tried to implement in the design it gave me following error:
"Signal output cannot be synthesized, bad synchronous description. The description style you are using to describe a synchronous element (register, memory, etc.) is not supported in the current software release."
I am not sure what is this error about. Below is my part of code which I guess is giving this error:
process(clk_plstr,plsrep) ----clk_plstr=10mhz;plsrep=2.5khz
begin
pls<=conv_std_logic_vector(n,12);
if rising_edge(clk_plstr)then
count<= count+'1';
end if;
if(count<=pls)then
if(clk_plstr'event and clk_plstr = '1')then
output<='0';
else
output<='1';
end if;
else
output<='0';
end if;
if (plsrep='1')then
count<=B"000000000000";
end if;
end process;
fout<=output;
It would be very helpful if anyone can point out the problem by which I am getting this error.
I would really appreciate your help.
Thank you
