12 years agoThere are some lines in your that may cause problems:
if rising_edge(plsrep)then count_reg<= B"000000000000" ; elsif(clk_plstr'event and clk_plstr='1')then count_reg<=count_next; end if; The rising_edge means that plsrep is used as a clock signal. In a synchronous system ( fpgas ) you have only one clock. You may try: if plsrep = '1' then count_reg<= B"000000000000" ; elsif(clk_plstr'event and clk_plstr='1')then count_reg<=count_next; end if; But plsrep in this code works like an asynchronous reset. So don't use reset in the register declaration: process(clk_plstr) begin if(clk_plstr'event and clk_plstr='1') then count_reg<=count_next; end if; end process; count_next <=count_reg+'1' when(count_reg=B"000000000000" and plsrep='1') else count_reg when (count_reg=B"000000000000") else count_reg+'1' when (count_reg<pls)else B"000000000000";
