12 years agoHi bretelus ,
Thank you for the sugesstion.It works if I used plsrep='1'. But when I try to output the clock pulse(clk_plstr here) then I again get the same error as: "Signal output cannot be synthesized, bad synchronous description. The description style you are using to describe a synchronous element (register, memory, etc.) is not supported in the current software release." The code to output this clock pluse looks like following: process(clk_plstr) begin .......... if(clk_plstr'event and clk_plstr = '1')then ----xst error to output like this? if(count_reg<=pls )then output<='1'; else output<='0'; end if; end process; It would be very helpful if you could point out the problem that I am getting now.Thank you
