evyatar's avatar
evyatar
4 years ago
setup timing from fifo
a strange setup timing violation:
the path is from the 'write enable' of a FIFO, to another register in the design.
it seems like a problem in the Quartus 2 (64 bit V14.1.0 B186 12/3/14 SJ Full Version) since we cant find this actual path in the design.
using the locate path command in the time quest, show me the path provided in the files below - its doesn't look like the path in violation list. also tried to understand the path with the nodes in the Data Path window but it seems a little bit confusing.
for example - locating the node `Equal0~datac` in the RTL viewer led me to a comparator, which its inputs are not the 'write enable', but 'lb_hc_rx_din' and another irrelevant input.
by the way, 'lb_hc_rx_din' is coming from the FIFO, which the 'write enable' in the violation path is its 'write enable', however I wasn't expecting it to be a problematic path since the FIFO RAM output is isolating the path (like a register).
is it possible there is a problem in the quartus, and this path should be a false path?
I am adding relevant files and screenshot. please can you help me find out what is the path and how to handle it?
regards
