evyatar
4 years agosetup timing from fifo
a strange setup timing violation: the path is from the 'write enable' of a FIFO, to another register in the design. it seems like a problem in the Quartus 2 (64 bit V14.1.0 B186 12/3/14 SJ Full Ver...
sstrell
4 years agoWithout seeing the design or the .sdc file, it's difficult to figure this out. Can you provide at least the .sdc and/or the code defining the failing path?
