evyatar
4 years agosetup timing from fifo
a strange setup timing violation: the path is from the 'write enable' of a FIFO, to another register in the design. it seems like a problem in the Quartus 2 (64 bit V14.1.0 B186 12/3/14 SJ Full Ver...
evyatar
4 years agoI will try it, however it may take some time, since I have IP Versions to upgrade, and it requires cooperation with some other colleagues.
do you have another suggestion ?
