evyatar
4 years agosetup timing from fifo
a strange setup timing violation: the path is from the 'write enable' of a FIFO, to another register in the design. it seems like a problem in the Quartus 2 (64 bit V14.1.0 B186 12/3/14 SJ Full Ver...
sstrell
4 years agoYou've got a very long interconnect delay going to this clock control block:
; 5.883 ; 4.766 ; RR ; IC ; 1 ; CLKCTRL_R6
for both the data arrival and data required paths. Did you manually add a clock control block to your design (as an IP) or with so many clocks, was the design forced to use this clock control block to distribute the clock for the failing path? Locate the failing path to the Chip Planner to see the physical placement and to determine if there are physical resource constraints on the path which is leading to this.
