17 years agoset_output_delay -min / -max does not have intended effect
Per earlier recommendations i have switched to TimeQuest in order to correctly constrain output signals in my design. The FPGA is a Cyclone II and i'm using Quartus II 7.1. I'm trying to achieve correct timing for a source synchronous output bus that drives an external FIFO. I have a 48 MHz clock, a 16-bit data bus and a 'write'-signal. The external FIFO requires the following setup and hold timings: data tsu_needed = 4ns data th_needed = 5ns write tsu_needed = 13ns write th_needed = 5ns Given the source synchronous interface, i'm using the following SDC Settings (the complete SDC file is attached): set_output_delay -add_delay -max -clock [get_clocks {CLK_OUT_48}] 13 [get_ports {N_SLWR}] set_output_delay -add_delay -min -clock [get_clocks {CLK_OUT_48}] -4 [get_ports {N_SLWR}] set_output_delay -add_delay -max -clock [get_clocks {CLK_OUT_48}] 4 [get_ports {DATA_OUT[15]}] set_output_delay -add_delay -min -clock [get_clocks {CLK_OUT_48}] -5 [get_ports {DATA_OUT[15]}] set_output_delay -add_delay -max -clock [get_clocks {CLK_OUT_48}] 4 [get_ports {DATA_OUT[14]}] set_output_delay -add_delay -min -clock [get_clocks {CLK_OUT_48}] -5 [get_ports {DATA_OUT[14]}] set_output_delay -add_delay -max -clock [get_clocks {CLK_OUT_48}] 4 [get_ports {DATA_OUT[13]}] set_output_delay -add_delay -min -clock [get_clocks {CLK_OUT_48}] -5 [get_ports {DATA_OUT[13]}] set_output_delay -add_delay -max -clock [get_clocks {CLK_OUT_48}] 4 [get_ports {DATA_OUT[12]}] set_output_delay -add_delay -min -clock [get_clocks {CLK_OUT_48}] -5 [get_ports {DATA_OUT[12]}] set_output_delay -add_delay -max -clock [get_clocks {CLK_OUT_48}] 4 [get_ports {DATA_OUT[11]}] set_output_delay -add_delay -min -clock [get_clocks {CLK_OUT_48}] -5 [get_ports {DATA_OUT[11]}] set_output_delay -add_delay -max -clock [get_clocks {CLK_OUT_48}] 4 [get_ports {DATA_OUT[10]}] set_output_delay -add_delay -min -clock [get_clocks {CLK_OUT_48}] -5 [get_ports {DATA_OUT[10]}] set_output_delay -add_delay -max -clock [get_clocks {CLK_OUT_48}] 4 [get_ports {DATA_OUT[9]}] set_output_delay -add_delay -min -clock [get_clocks {CLK_OUT_48}] -5 [get_ports {DATA_OUT[9]}] set_output_delay -add_delay -max -clock [get_clocks {CLK_OUT_48}] 4 [get_ports {DATA_OUT[8]}] set_output_delay -add_delay -min -clock [get_clocks {CLK_OUT_48}] -5 [get_ports {DATA_OUT[8]}] set_output_delay -add_delay -max -clock [get_clocks {CLK_OUT_48}] 4 [get_ports {DATA_OUT[7]}] set_output_delay -add_delay -min -clock [get_clocks {CLK_OUT_48}] -5 [get_ports {DATA_OUT[7]}] set_output_delay -add_delay -max -clock [get_clocks {CLK_OUT_48}] 4 [get_ports {DATA_OUT[6]}] set_output_delay -add_delay -min -clock [get_clocks {CLK_OUT_48}] -5 [get_ports {DATA_OUT[6]}] set_output_delay -add_delay -max -clock [get_clocks {CLK_OUT_48}] 4 [get_ports {DATA_OUT[5]}] set_output_delay -add_delay -min -clock [get_clocks {CLK_OUT_48}] -5 [get_ports {DATA_OUT[5]}] set_output_delay -add_delay -max -clock [get_clocks {CLK_OUT_48}] 4 [get_ports {DATA_OUT[4]}] set_output_delay -add_delay -min -clock [get_clocks {CLK_OUT_48}] -5 [get_ports {DATA_OUT[4]}] set_output_delay -add_delay -max -clock [get_clocks {CLK_OUT_48}] 4 [get_ports {DATA_OUT[3]}] set_output_delay -add_delay -min -clock [get_clocks {CLK_OUT_48}] -5 [get_ports {DATA_OUT[3]}] set_output_delay -add_delay -max -clock [get_clocks {CLK_OUT_48}] 4 [get_ports {DATA_OUT[2]}] set_output_delay -add_delay -min -clock [get_clocks {CLK_OUT_48}] -5 [get_ports {DATA_OUT[2]}] set_output_delay -add_delay -max -clock [get_clocks {CLK_OUT_48}] 4 [get_ports {DATA_OUT[1]}] set_output_delay -add_delay -min -clock [get_clocks {CLK_OUT_48}] -5 [get_ports {DATA_OUT[1]}] set_output_delay -add_delay -max -clock [get_clocks {CLK_OUT_48}] 4 [get_ports {DATA_OUT[0]}] set_output_delay -add_delay -min -clock [get_clocks {CLK_OUT_48}] -5 [get_ports {DATA_OUT[0]}] Unfortunately, the timings as measured by my Logic Analyzer attached to LAI pins on the FPGA shows that the following timings result: data th_actual = 1.3ns write th_actual = 2ns Changing the -min time to something more negative does not affect the hold time a bit. Any ideas where to start debugging this? Thanks, /John.
